pipingbob
North Carolina
I just purchased a new Jayco pop-up camper. I would like to install some type privacy curtain around the porti-potty but do not have a clue of how to do it. I am open to all suggestions.
Thanks in advance
Merrykalia
Appalachian (apple at chun) Mountains in SW VA
If you just want something easy, use an old shower curtain along with the rings around a hula hoop ($1 at dollar stores). Put 3-4 pieces of string around the hoop that will come to a point for hanging. Use some heavy duty velcro strapping to keep it hanging from the ceiling.
bondebond
Searcy, AR
Without putting any holes in the ceiling, simply put self-adhesive velcro strips on the ceiling and on a shower curtain.
This makes for a fast set up/take down. It also let's you play with location until you are satisfied. Don't use the industrial strength, as I pictured, if you think you'll want to re-position it.
I use self-adhesive Velcro all over the PUP until I am convinced that whatever it is is going to be permanent. You have to work slowly to roll the Velcro off of the wall or ceiling, as you can pull the finish off if you just pull quickly. Then I'll use some anchor bolts at that point.
This space left intentionally.
2006 Fleetwood Sequoia and mods...one of the tallest highwall pop-ups on the planet after flipping the axle.
RoyB
King George, VA
My 2008 14RT Starcraft OFF-ROAD POPUP came with a shower curtain for the shower and cassette pottie area. It also has a privacy curtain that runs from the door area to the wall to block off that area of the trailer.
they used these "turn buttons" mounted in the ceiling to hold up the curtain slide rails with hooks.
You can kinda get an idea of the ceiling mounted hardware here in this photo showing both shower curtain and privacy curtain in a POPUP.
photos from google images
Roy and Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
POPUP PHOTOs-Pg52-Pg56
alid
Newfield, NJ
pipingbob wrote: I just purchased a new Jayco pop-up camper. I would like to install some type privacy curtain around the porti-potty but do not have a clue of how to do it. I am open to all suggestions.
Thanks in advance
I would use a shower curtain with grommets. Then use some 3M command hooks on the ceiling. 3m commmand hooks
2009 Winnebago Adventure 32h
2006 Terry Quantum 330FKDS (beach getaway)
2003 Aprilia Atlantic 500
2007 Honda Reflex
2 house rabbits "Roo and MiMi"
wittmeba
Virginia
Might consider starting with something like these:
Shower Curtain Enclosure Rods
I was born in Great Falls, Mt. My parents moved when I was 5. I found them when I was 10 - they were in California.
Firefox® 21.0
Log home images - Updated 05/19/2013
stubblejumper
Saskatchewan
Get a full circle ceiling mounted shower curtain rod that is used over a free standing footed bathtub. Lowes, HD, Ace.
1999 Winnebego Chieftain
Wayne & Leila and Teddi (the Kid in the brown fuzzy pyjamas)
We are not 2 people that own a dog, we are 2 people that are owned by a dog ..
