RV.Net Open Roads Forum: Beginning RVing: Mobile Internet
 > Mobile Internet
meltingcube
US
Posted: 05/02/12 07:58pm Link  |  Print  |  Notify Moderator
Hey Everyone,
I'm planning to start on a long trip in a travel trailer. My job allows me to telecommute thus as long as I have access to power and reliable internet, I'm golden. At the moment I have a smartphone with Verizon that has an unlimited data plan which I can tether assuming there is proper cell coverage.
What I need though is a backup in case Verizon doesn't have coverage where I am, or they decide to cut me off. From looking around the best options I could find had a monthly data cap of 12GB. This is insanely low and something I'd blow through in less than 3 days.
Do any of you have any reliable nation-wide internet options that you would recommend, or would satellite internet (which is crazy expensive) be the only other alternative?
Thanks.
rr2254545
Minnesota
Posted: 05/02/12 08:08pm Link  |  Print  |  Notify Moderator
I have 5 GB with my Verizion MIfi plan, that is a bunch of data. What are you doing that 12 is too little?
2012 Winnebago Journey 36M Cummins 360
131 Campgrounds since we retired in July 2009
miatared
Toronto, Ontario
Posted: 05/02/12 08:23pm Link  |  Print  |  Notify Moderator
X2. That is a lot of data...you hosting an FTP server?
Kirk
Livingston, Texas.
Posted: 05/02/12 08:19pm Link  |  Print  |  Notify Moderator
There is only one way to have certain internet connection wherever you choose to go, and that is via via satellite dish.
Good travelin! ........Kirk
Professional Volunteer
Fulltimer for 11 years,
URL: www.adventure.1tree.net
meltingcube
US
Posted: 05/02/12 08:26pm Link  |  Print  |  Notify Moderator
My job is completely on the internet and requires a constant connection through a VPN. My normal usage is 5-6GB a day which is mainly web browsing, but includes IM, Skype, and SSH.
I'm sure that even for a normal user 12 GB will be too little as well. Streaming one movie will typically take 2-3 GB of data alone.
louiskathy
Oregon (presently)
Posted: 05/02/12 08:29pm Link  |  Print  |  Notify Moderator
Look into a Millenicom mifi ...The deal i have is 20G 3G/4G for under $70/month. If I'm in a 4G area, then I'm whacked back to 10G for my monthly amount. I find very few places where I go that have 4G speed.
I also use a Wilson cradle (which is VERY uncomplicated and easy to use). Bought that from the 3G store online. Boosts my signal on my mifi unit and I can also lay my cell phone on it and get a better signal as well. (Cell phone is Sprint).
I was able to do text email in Yosemite Valley a few weeks ago and i was able to get a good phone signal (no internet) in Death Valley with what I have.
Just do a search on rv.net for Millenicom or Wilson Cradle and you should get all kinds of info.
Kathy
meltingcube
US
Posted: 05/02/12 08:35pm Link  |  Print  |  Notify Moderator
Thanks. It looks like they offer an unlimited plan however how is the coverage with it? Their coverage page is throwing errors for me so I cant check myself.
sdianel
Tampa, FL
Posted: 05/02/12 08:40pm Link  |  Print  |  Notify Moderator
I have Verizon Mi-Fi. Verizon has a 10GB plan for $80 per month and each additional GB is $10 per month. We have used Verizon all over the US with only a couple of times when we didn't get a good enough signal to get online. It's much faster than when I tethered the phone. I also use a Wilson Sleek booster for fringe areas (you can order them thru walmart or amazon.com). Verizon also has business plans and VPN of your company is paying.
Lonny & Diane
2004 Country Coach Allure 33' "Big Blue"
Towing 2008 Chev Colorado 4x4
Semper Fi
pianotuna
Regina, SK, Canada
Posted: 05/02/12 09:13pm Link  |  Print  |  Notify Moderator
Hi,
You may find that Verizon will throttle your bandwidth even if the plan is supposedly unlimited. It will be back to dial up speed.
Millenicom does have a 20 gig Verizon plan and a 50 gig Sprint plan. For the kind of data you are using I'd get both, and then put them into a cradlepoint wifi router so the bandwidth (and speed) could be shared too.
Sprint doesn't have a lot of coverage in the Midwest.
Regards, Don
Kustom Koach Class C 28'5" 256 watts Unisolar, 875 amp hours in two battery banks 12 volt batteries, 2500 MSW watt inverter.
meltingcube
US
Posted: 05/02/12 10:28pm Link  |  Print  |  Notify Moderator
Thanks everyone. I think I've found what I wanted, or at least found the right direction.
 > Mobile Internet
