RV.Net Open Roads Forum: Class A Motorhomes: Engine Brake
 > Engine Brake
mrubaum@aol.com
california
Posted: 05/04/12 10:48am Link  |  Print  |  Notify Moderator
Does using your engine brake increase fuel consumption?
mowermech
Billings, MT
Posted: 05/04/12 10:52am Link  |  Print  |  Notify Moderator
I never noticed any increase in fuel consumption when using it.
CM1, USN (RET)
Toad: 2006 Jeep Rubicon LJ
VintageRacer
Dundas, Ontario
Posted: 05/04/12 10:58am Link  |  Print  |  Notify Moderator
Infinitesimally. Consider that an engine brake is on a diesel engine, and that it only comes on when the engine is on over-run (truck pushing the engine, basically), so the engine is in a no-fuel condition (unlike gas engines, diesel engines inject no fuel when on over-run). That means there is no fuel being consumed while the engine brake is on, or off when coasting down a hill. The only reason is will consume a truly tiny bit more fuel is if you coast down the hill you'll be going a whole lot faster at the bottom, and be able to coast farther up the other side of the valley... In the real world if you do over-use the engine brake when you could be quite safely coasting at a slightly higher speed, you will use a bit more fuel. If you were going to use the service brakes anyway, no difference.
Brian
Brian
2005 F250 Supercab, Powerstroke, 5 speed automatic, 3.73 gears.
20 ft race car hauler, Lola T440 Formula Ford, NTM MK4 Sports Racer
1980 MCI MC-5C highway coach conversion
2004 Travelhawk 8' Truck Camper
zmotorsports
Utah
I would say it depends on how you use it. The exhaust brake itself will not use any fuel per say as it is not fueling when the throttle is released. However, many times engaging it unnecessarily and not allowing the coach to "coast" can use more energy (fuel) than really needed to get it going again. I like to use my "coast" gear as much as possible. This involves looking quite a distance ahead and timing stops/starts as efficiently as possible and not slowing too soon or too abruptly just to have to get all of that weight moving again.
Hope that makes sense.
Mike.
2003 Monaco Dynasty/ 26' Haulmark Edge trailer
2011 Jeep Unlimited Rubicon
Executive
First question that comes to mind is are you asking about an engine brake or an exhaust brake...two very different animals. Depending on the usage the engine brake will consume a slight amount of fuel as it re-establishes engine power. However, that consumption is more than overcome by the savings realized in brake usage and slowing power. Those that use the engine brake, and the exhaust brake for that matter, tend to alter their driving habits significantly so the fuel savings does add up. Either way, unless you were doing a very controlled experiment, you would not notice any change, either up or down.....Dennis
Dennis and Debi
Chevy HHR W/ ReadyBrute
Fourth Year Full Timing Click here to view our travel blog
Effy
MD
Posted: 05/04/12 11:10am Link  |  Print  |  Notify Moderator
I would think the type of engine per the question would be critical. Is it gas or diesel? My gas v-10 has an engine brake but I imagine it's a glorified way of forcing it to stay in a lower gear which results in higher rpm but the lower gear applies drag rather than free falling down a hill. Much like downshifting a manual trans in a car to slow you down. But since the rpm is not caused by my manual induction of more gas but rather more by way of gravity applied force to "push" the engine I doubt it uses more fuel. And if it did I am sure it's immeasurable. Frankly I don't care. It's keeping my brakes from overheating.
2012 Thor ACE 29.1
wolfe10
Posted: 05/04/12 12:42pm Link  |  Print  |  Notify Moderator
Mike.
YUP. Not coasting WILL cost you MPG!
Said another way, if you leave it on, you will either be applying accelerator or brakes. If you are interested in MPG, you need to add COASTING to the equation.
Brett Wolfe
1997 Safari Sahara 3540
EX: 1993 Foretravel 36' U-240
Ivylog
Blairsville, Ga. USA
Posted: 05/05/12 05:37am Link  |  Print  |  Notify Moderator
Uses the same amount of fuel as using your regular brakes.
04 Monaco Dynasty 42' quad slide
Where am I?
How I tow.
 > Engine Brake
