RV.Net Open Roads Forum: Beginning RVing: holding tank treatment
 > holding tank treatment
thoms
tampa, fl.
Posted: 05/05/12 12:49pm Link  |  Print  |  Notify Moderator
Hi all,
has anyone ever used Nature Zyme tabs in there holding tank?
It says to add 1 tab to 12 oz.of water and add to tank. but not to add any more water. I guess this would be fine if you are camping and using it right away but what if you camper is not being used for a month or so?? Should this product still be add to the tank with only 12 oz of water? I am used to emptying the tanks then adding a little water and a liquid treatment when we get home, can`t remember what one. Any input on this product would help.
Thanks
powderman426
ohio
Posted: 05/05/12 01:33pm Link  |  Print  |  Notify Moderator
They call it a holding tank for a reason. Just be sure to use enough liquid to keep it from solidifying. If you need some place your money, you can send it to me.
Ron & Charlotte
WD8CBT since 1976
28' Prowler & 05 Ram QC LB
I started with nothing and I still have most of it left
I never fail, I just succeed in finding out what doesn't work
robsouth
Near Atlanta, GA
Posted: 05/05/12 02:41pm Link  |  Print  |  Notify Moderator
All you need in the tanks is water. Enough to keep anything from solidifying and enough to "flush" rapidly when dumping. Then run some more water in and dump again if you don't have tank sprayers. No chemicals are needed as this is a holding tank not a septic tank. You might just add some Calgon water softener to help the water along.
"Sometimes I just sit and think. Sometimes I just sit." "Great minds like a think."
Jack&Kay
Santa Rosa, Ca
Posted: 05/05/12 04:05pm Link  |  Print  |  Notify Moderator
If you want to use something, try this:
Happy Camper
I've been using it for more that 5 years and it works well. Also lost of water, can't forget that.
Jack & Kay
2007 Tiffin Allegro 28DA
Ford Chassis V-10
Blue Ox Tow Bar to a 94 Honda Accord
FMCA #F341229
lanerd
Newport, OR
Posted: 05/05/12 04:09pm Link  |  Print  |  Notify Moderator
Forget any additive... they're not needed. Keep plenty of water in your tanks and when you drain them, make sure that they are clean of any left over stuff in there. Refilling and draining again will help. Get a clear connector so that you can see if the water coming out is free of any lingering offenders.
Ron
Ron & Sandie
'08 Safari Simba SBD35 CAT C7
Toad: 2011 GMC Terrain SLT2
Tow Bar: Sterling AT
Toad Brakes: Unified U.S. Gear
TPMS: Pressure Pro
Member of: GS, FMCA, Safari Intl, CAT
RETIRED!! How sweet it is....
tvman44
Southwest Louisiana
Posted: 05/05/12 05:46pm Link  |  Print  |  Notify Moderator
After emptying my tanks I put a few gallons of clean water only in the tanks to keep everything moist, been doing that for about the last 5 years and works great. The money I would have spent on additives buys more diesel to go somewhere.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
Billieg2
Gone from this forum
Posted: 05/05/12 06:10pm Link  |  Print  |  Notify Moderator
I buy pine cleaner $1.99 at the dollar store it comes in a 1/2 gallon size. I dump about 2 cups in after dumping and add about 5 gal water. The oil keeps things from sticking and the pine smell does the job. It also helps the sensor to stay clean. Been doing it for years and no smell and no problems.
In my life I've spent my money on women, booze, Harleys, guitars and traveling, the rest I just wasted...
2007 Ford F-350 diesel/dually & Sunnybrook Titan KSRV 39-1 Toy hauler 5th wheel hauling my custom Harley
Ron3rd
Upland, CA USA
Posted: 05/05/12 08:47pm Link  |  Print  |  Notify Moderator
That's an excellent idea as the chems are just deodorizers anyway. I'll bet the pine stuff works as good as anything on the market.
2004 Aljo 250LT
Eaz-Lift WD Hitch
Single Friction Sway Control
Prodigy Brake Controller
Honda EU2000
Allegheny N F Camper
Pennsylvania
Posted: 05/07/12 09:24pm Link  |  Print  |  Notify Moderator
WATER WATER WATER WATER WATER I only use water and lots of it. Every time I dump I put two 5 gal buckets of fresh back in right away. One time with the brown mound was more than enough for a life time. Wife thought the black was full once when I wasn't there so she tried to drain it but only open the valve a little and didn't get it completly closed.
Billieg2
Posted: 05/08/12 09:20am Link  |  Print  |  Notify Moderator
The reason stuff sticks is because the tank is plastic and rough. Using something like Pine cleaner will lube the tank and valves so nothing sticks. At a $1.99 at the dollar store it's cheap insurance. Of course you also need a lot of water to flush it away and should always fill it with water before flushing.
