RV.Net Open Roads Forum: Bought my boondocking TT
Search only in Public Lands, Boondocking and ...
Open Roads Forum  >  Public Lands, Boondocking and Dry Camping
 > Bought my boondocking TT
colliehauler
Mc Pherson KS USA
Posted: 05/05/12 07:09pm Link  |  Print  |  Notify Moderator
After looking for a while I finally bought a small (relatively speaking) TT. I wanted a small TT with a built in generator and large tanks. I wound up with a used small 2008 Cherokee 17DFWP TH. It has 62 gal of fresh water, Has floor space for three large Collies, Is generator ready with a built in fuel tank. While the trailer is 17' overall length is 22'. High ground clearance. 15" tires with over 2k# payload. Now the bad. It's heavy at 4880#, and they call it a lite. Has almost no storage. A little tall and is stick and tin construction. They stopped making this model so I had to buy used. It's clean and well cared for so I did not mind. I liked the small Wildwood 18srvt but no place for a generator. It was less tall and only weighed 3200#.
profdant139
Posted: 05/05/12 07:37pm Link  |  Print  |  Notify Moderator
62 gallons? Those must be thirsty collies! If you tow it dry, it'll weigh 500 pounds less, if my math is right (which it rarely is).
Congratulations! Where are you going on your first trip??
Our trips -- pix and text
About our trailer
pianotuna
Regina, SK, Canada
Posted: 05/05/12 07:39pm Link  |  Print  |  Notify Moderator
Hi,
Congratulations on the new RV!
If the electrical use won't include an air conditioner consider a solar system instead--and fill up the generator compartment with batteries.
Costs for the Solar part of the system if you DIY are about $2.00 per watt.
Regards, Don
Kustom Koach Class C 28'5" 256 watts Unisolar, 875 amp hours in two battery banks 12 volt batteries, 2500 MSW watt inverter.
colliehauler
Mc Pherson KS USA
Posted: 05/05/12 08:37pm Link  |  Print  |  Notify Moderator
The first camp out will be at the dealer. I have to drive 9 hours to pick it up. They will have it set up for me to use. I bought this for a trip to Alaska. I'm towing with a 3/4 ton Diesel so the weight will be more of that cheep fuel.
colliehauler
Mc Pherson KS USA
Posted: 05/05/12 08:44pm Link  |  Print  |  Notify Moderator
pianotuna wrote:
Hi,
I have to have my A/C. On most trips it will not be used but if it gets warm I'll have it. I will use two 6 volt batteries and might add a solar panel. I have gone a week on just two 6 volt batteries.
Golden_HVAC
Fulltime, CA, USA
Posted: 05/06/12 02:20am Link  |  Print  |  Notify Moderator
Hi,
With the CO detector, propane detector and refrigerator using 35 amp hours per day, it is really difficult to go a week with 220 amp hours of battery power, unless you have at least 100 watts of solar panels. And 100W will barely put back the 35 AH used daily by just the refrigerator and detectors.
SunElec.com has some good deals on solar panels, in the $2 per rated watt range. If you select a 12 volt panel, then a low cost controller can turn it on and off for about $65. They where selling a 195 watt panel with 18 volt output (12 volt nominal) for $265 a couple of months ago, but don't have any more in stock last time I checked their website, you can always call and ask about current stock, and when more 12 volt panels will arrive.
You can add more tank space at this place Tank-depot.com
My suggestion is if this will be a hunting trailer, or going out on snow machines, then use a 6,000 Btu Olympic Catalytic heater, no battery power at all, and you need to leave two roof vents open slightly, I used Maxx air covers on all my roof hatches, and leave a window slightly open. The RV should stay toasty warm even at 15F outside. Mine keeps my 30' Bounder at 70 when it is above 25F outside, and I run the furnace a little bit if below 25. I have dual pane windows, basement that is kept warm, and a little more length, so I think you should stay equally warm with a shorter RV, less insulation, and single pane windows.
Fred.
Mello Mike
Mesa, AZ
Posted: 05/06/12 08:08am Link  |  Print  |  Notify Moderator
Congrats on the new addition. Post pics when you can.
2011 Wolf Creek 850N/Polar Cub/240w Solar/2-6v Lifeline AGMs/Morningstar Sunsaver w/RM-1 & SureSine-300 Inverter
2011 Ford F-250/6.2L/3.73/Bilsteins/Air Bags/Torklift TD w/Fastguns
2004 Jeep Wrangler/4.0L/5-spd
US Navy Ret.
My Truck Camper Adventure Blog
pnichols
Santa Cruz Mountains
Posted: 05/07/12 10:03pm Link  |  Print  |  Notify Moderator
Congrats on the great TT!!!
....outstanding built-in fresh water capacity versus it's size, too. The ground clearance looks to be very good for remote area boondocking.
Koodoos on also wanting generator power in it. IMHO, solar is OK but not alone ... for good RV flexibility it must be combined with some generator capability.
Phil, 2005 E450 Itasca 324V Spirit
