Farmer David
Mattoon, ILL.
For you folks that are schooled on dc power I have a question for you. I plan on making me a bracket to mount my winegard carryout to my pin box. I have to plug it into 12 volt outlet somewhere. In the 7 pin plug (Plug that you plug into your truck) when uphooked from truck there is a hot wire in there and a ground Is there any reason I couldn't just get me a female 7 pin outlet and put a pigtail on it to a 12 volt outlet for use for my winegard. Thee plug is just hanging there right where I will need it.
2013 F450 King Ranch CC Long Box
60 Gal RDS Tank
20K B&W OEM Hitch
2013 Lifestyle 37IK
CA Traveler
The Western States
Good plan, go for it.
2009 Holiday Rambler 42 Scepter with ISL 400 Cummins
2004 Honda CR-V
Bob
2oldman
Winchester WA
A garden battery may work too.
John Wayne
Long Beach, Ca
You can do that I'd put a fuse on the power side to the antenna.
John & Carol Life members
01 31'Sea View single slide, F53 V-10
96 Toyota 4-Runner auto 4x4 (Remco, M&G brake system)
Security by Bentley
God Bless
KF6HCH
YC 1
Yuba City Calif.
Good idea. I would suggest a fuse near the plug in case the wire gets shorted. Without a fuse it could start a fire in the grass if placed there.
H/R Endeavor 2008
2007 Hummer H3 toad
Ranger Boat
hershey
Albuquerque,(fulltime) NM, USA
12 volts is 12 volts no matter where you get it. Go for it.
hershey - albuquerque, nm
Someday Finally Got Here
Superman was an illegal alien.
NASCAR 14 - 99
tvman44
Southwest Louisiana
Will not work on a Ford as the key has to be on for the hot wire to be activated in the 7 pin connector.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
KD4UPL
Swoope, VA
tvman44 wrote: Will not work on a Ford as the key has to be on for the hot wire to be activated in the 7 pin connector.
He's talking about hooking into the trailer cord. Not the truck outlet.
Truck brand is irrelevant.
Farmer David
Mattoon, ILL.
Thanks guys I thought it would work but thought I would check
