RV.Net Open Roads Forum: Straps fpr wondow awning that is built into the side topper
 > Straps fpr wondow awning that is built into the side topper
ROYBUCK
Newport NC
Posted: 05/06/12 04:17pm Link  |  Print  |  Notify Moderator
I have a 2002 endeavor with the all in one side topper and window awning, the straps gets flanted out to the extent I cannot get my hook into the strap, does anyone have this problem, if so how did you correct the problem. Thanks Roy
Roy B Coal Miners Son
USMC Ret
Semper Fi
2002 Endeavor 330 ISC 3 Slides
hottubkid
SCHAUMBURG,IL
Posted: 05/06/12 04:37pm Link  |  Print  |  Notify Moderator
Cut a small piece of rubber and put it inside the loop. The rubber trying to go flat again opens the loop
hottubkid60193@yahoo.com
2004 SOUTHWIND 36E Tow 2003 CRV
JNW57
HONDO,TX
Posted: 05/06/12 05:16pm Link  |  Print  |  Notify Moderator
Grind the awning rod on two sides & make it look like a flat blade screwdriver & it will help your insertion into the strap.
2003 DISCOVERY 39L QUAD SLIDE
2003 CHEVY TRACKER ZR2 4x4
Blue Ox Aladdin, Brake Safe, Kar Guard
louiskathy
Oregon (presently)
Posted: 05/06/12 06:09pm Link  |  Print  |  Notify Moderator
We just put a loop of thick string into the existing strap. It hangs down a bit and that makes it easier to find and much easier to snag with the hook.
Kathy
Nomadac
Columbus, IN
Posted: 05/07/12 02:52pm Link  |  Print  |  Notify Moderator
X2
Arnie
2003 Travel Supreme MH
38KSO1 Cummins ISC 350HP
2004 Honda Pilot w/SMI Air Force One Brake Sys.
1963 Pontiac Grand Prix 20' Enclosed Car Trailer
B's Bunch
Shelbyville, TN. USA Why live any where else?
Posted: 05/07/12 05:28pm Link  |  Print  |  Notify Moderator
If it does not roll up into the awning I would try inserting a short piece of maybe 1/2 or 3/4" pvc into the loop and leaving it to stabalize the loop and maybe it will stay open for future use. Wont hurt to try. Larry
Larry,Brenda,Travis,Jarred & MEME the Boston Terror TheBunch 2011 American Coach Revolution 42T
ROYBUCK
Newport NC
Posted: 05/07/12 08:22pm Link  |  Print  |  Notify Moderator
Since it is a all in one the strap rolls up in the awning that is what flatening it out, I guess I will grind the rod like was posted. Thanks overyone. Roy
