RV.Net Open Roads Forum: Travel Trailers: Blackwater Clean out Leaking -Heartland Northtrail
 > Blackwater Clean out Leaking -Heartland Northtrail
mtwright
South
Posted: 05/07/12 02:34pm Link  |  Print  |  Notify Moderator
I'm a brand new TT owner (32BUDS Heartland North Trail)and went on my first camping trip this past weekend. One of the features I was told was beneficial (when purchasing my trailer) was the external black water tank clean out. I used it for the first time this weekend when breaking down the trailer. I followed the instructions to a tee, open black water dump valve, hook up hose, turn on water...etc. but when I did...water leaked out of the piping into the bathroom. When looking at the plumbing...there appears to be either a threaded PVC cap or a vent on the piping...where the water was coming from. Has anyone else had a similar problem? Know a fix? How should I handle this? Now I'm afraid to use the clean out...Advice please?
dbbls
Missouri
Posted: 05/07/12 03:44pm Link  |  Print  |  Notify Moderator
I would take it back to the dealer. That should be a warranty repair.
2011 F-350 CC Lariat 4X4 Dually Diesel
2012 Big Country 3450TS 5th Wheel
BarneyS
S.E. Lower Michigan
Posted: 05/07/12 04:08pm Link  |  Print  |  Notify Moderator
Unless the dealer is close by and easy to take the trailer back to, I would unthread the thing and take it to Home Depot or Lowes plumbing section. I believe they have those devices in stock. I forget what they are called though - maybe a vacuum relief valve. They let air in the lines to equalize pressures for the P traps or something like that. They are supposed to be a one way valve but frequently break or don't work correctly.
Barney
* This post was edited 05/07/12 04:27pm by BarneyS *
Hensley "Arrow" 1400# hitch
2002 Ford F250 Super Duty, 7.3L PSD
Visit our website here
HappyKayakers
Black River Falls WI
Posted: 05/07/12 05:27pm Link  |  Print  |  Notify Moderator
I own an '06 Heartland Bighorn. The first time I used my Saniflush, I could see water coming out of the bottom of the RV, under the commode area. Took it back to the dealer for that item and a few other things. There is a check valve that's apparently required by RV code and has to be higher than existing plumbing in the RV. Mine was routed behind and above the toilet. Someone at the factory didn't tighten up the connections to the check valve properly. I'm really surprised it didn't burn out my converter.
Joe and Dakota, the wacko cat
2006 Dodge 3500 QC CTD SRW Jacobs Exhaust brake
2006 Heartland Bighorn 3600RL, MorRyde suspension, TrailAir pinbox
http://happykayakers.com/blogger/
WandaLust2
TN
Posted: 05/07/12 07:33pm Link  |  Print  |  Notify Moderator
I have a Heartland BRS28. Leaks plagued us constantly. No one checks to see if the workers tighten connections or if anything leaks before it leaves the factory. Never again........
I hope my DH got them all fixed now.
WandaLust. Retired. Middle TN
Heartland 2011 NorthTrail 28BRS
1993 Ford Dutchman Class-C
JoyceandSteve
Houston, Texas
Posted: 05/08/12 06:18am Link  |  Print  |  Notify Moderator
I had to have a the check valve replaced on mine, under warranty thank goodness. Now each time I use it I send the DW inside to make sure it isn't leaking. Last time there was no line at the dump station and I let it run for quite some time. DW thought maybe I forgot about her...haha
Steve & Joyce
2011 Chevrolet 2500 Z71 4X4
2013 Montana High Country 343 RL
1996 Celebrity 200 Boat
2000 Yamaha 1200 LTD Waverunner
2012 Ford Mustang GT (Mama's ride)
Vítejte na víkend doma a Steve Joyce
goducks10
Keizer OR
Posted: 05/08/12 08:21am Link  |  Print  |  Notify Moderator
I've only used our black tank flush a 1/2 dozen or so times but never had a problem. But I will say this, why did they put it on the opposite side as the dump valves? Why not the same side as to make it easier to hook the hose up while draing the tanks.
fjm039
a
Posted: 05/08/12 09:13am Link  |  Print  |  Notify Moderator
I have a 32 BUDS and had the exact same problem the first time I used it. Another poster said it, I don't believe they have people checking to see if the plumbing fixtures/lines are tightened. Sink in kitchen was loose as well.
I would first just check to be sure it is tightened. If not, take it back.
Heartland has very good quality, great customer service, and great product for the money but they most definitely lack in quality control.
Jeff
mtwright
South
Posted: 05/11/12 09:26am Link  |  Print  |  Notify Moderator
Thanks for all the replies! wow...this forum thing really works...
