RV.Net Open Roads Forum: Travel Trailers: breakaway cable mount conflict?
 > breakaway cable mount conflict?
DE88ROX
West Michigan. The other West Coast
Posted: 05/09/12 06:40am Link  |  Print  |  Notify Moderator
Chad/Jen wrote:
Thanks De88Rox. Is there any way I can tell which one I need (4' or 6'), since i assume longer isn't necessarily better in this case?
The 4' or 6' foot length is measured after its stretched out.
I just bought the 4' length. My switch is only about 18" behind the hitch and since I attach it in the same hole as one of my chains, there really is no fear about it getting stretched out and inadvertently getting pulled.
TV- 2010 GMC Sierra Z71 EXT. cab
TT- 2012 Starcraft Autumn Ridge235fb
gijoecam
Midwest
Posted: 05/09/12 06:54am Link  |  Print  |  Notify Moderator
Not to hijack, but...
DE88ROX wrote:
{snip}since I attach it in the same hole as one of my chains, {snip}
Bad form. What if the receiver fails? It has been known to happen... The breakaway should be attached to something OTHER than the same point as the safety chains, preferably something that will remain attached to the vehicle if the receiver doesn't. In my case, the chains go to the receiver, the breakaway attaches to the towing bumper. I would literally have to lose the last four feet of frame behind the axle for both connection points to disappear simultaneously.
DE88ROX
Posted: 05/09/12 07:00am Link  |  Print  |  Notify Moderator
So how do you attach it to your bumper?
gijoecam
Midwest
Posted: 05/09/12 07:23am Link  |  Print  |  Notify Moderator
Not sure exactly what you're asking, so I'll answer twice.
With a threaded quick-link, just like the safety chains go on the receiver.
Because the rear step bumper on my Ford is also a towing bumper, it has two holes that safety chains would normally attach to. The afore-mentioned quick-link attaches to one of the two safety chain attachment holes on the bumper.
rgolding
Southern Illinois
Posted: 05/09/12 07:34am Link  |  Print  |  Notify Moderator
The way I have read some state laws, you are doing it correctly. I've not found that place, yet, on my Chevy 2500HD.
gijoecam
Midwest
Posted: 05/09/12 07:54am Link  |  Print  |  Notify Moderator
Is there a hole on the frame rail someplace close by? What about a bumper mounting bracket? If nothing else, choke the cable around the bumper itself maybe? It wouldn't be pretty, but it would be functional... Heck, I'm pretty sure a nylon or velcro strap wrapped around the bumper with the cable attached to it would work fine too. It doesn't take much force to pull the pin out...
DE88ROX
Posted: 05/09/12 01:59pm Link  |  Print  |  Notify Moderator
On my GMCs step bumper. I have 3 knock outs in the vinyl step cover. One for the ball and two for the chains.
rgolding
Southern Illinois
Posted: 05/10/12 10:19am Link  |  Print  |  Notify Moderator
Good thread. It got me thinking and looking under the rear of the Chevy 2500HD. Found 2 holes near the attachment of the receiver hitch frame, but not part of it. I was able to work a "quick link" through the 2 holes and now have an attachment for the "break away chain" seperate from the frame of the receiver hitch framework.
Thanks for bringing up this point.
JBarca
Dublin, Ohio, USA
Posted: 05/10/12 10:39am Link  |  Print  |  Notify Moderator
Here folks. See if this helps.
Ford looks like this.
To keep the cable out of the chains
GM looks like this
Sorry have not owned Dodge or other TV's....LOL
Hope this helps
John
John & Cindy
2005 Ford F350 Super Duty, 4x4; 6.8L V10 with 4.10
CC, SB, Lariat & FX4 package
21,000 GCWR, 11,000 GVWR
Ford Tow Command
1,700# Reese HP hitch & HP Dual Cam
2 1/2" Towbeast Receiver
2004 Sunline Solaris T310SR
(I wish we were camping!)
Chad/Jen
Posted: 05/10/12 11:04am Link  |  Print  |  Notify Moderator
Thanks for the pictures. That really helps, especially since I haven't looked under my TV yet. What's a shock cord? I probably recognize the item but not the term.
