2ndhom
Eugene, Oregon
Seems to be ..... "it's all about me" generation!!!
mowermech
Billings, MT
2ndhom wrote: Seems to be ..... "it's all about me" generation!!!
One should always remember, the OTHER side may be thinking the same thing about YOU!
There are always two sides (at least) to every story.
Besides, the "ME generation" has been around for several hundred years!
CM1, USN (RET)
Toad: 2006 Jeep Rubicon LJ
M GO BLUE
Southgate, MI
You choose to park near me or next to me then I reserve the right to run my generator whenever I want and for whatever reason I want...period!
2005 Chevy Silverado 3500 dually CC/LB Duramax/Allison
2008 Jayco Designer 35RLTS fifth wheel
Onan 5500W Marquis Gold gas generator (HGJAB - 1038D)
MICHIGAN RALLY - July 19-21, 2013 Click here
2oldman
Wilson Creek WA
M GO BLUE wrote: I reserve the right to run my generator whenever I want and for whatever reason I want...period! Usually that works, but in cases of crowded spaces and no wind, generator exhaust can be not just stinky, but deadly.
M GO BLUE
Southgate, MI
2oldman wrote: M GO BLUE wrote: I reserve the right to run my generator whenever I want and for whatever reason I want...period! Usually that works, but in cases of crowded spaces and no wind, generator exhaust can be not just stinky, but deadly.
Unless you have a Genturi like I do...
harleyman1340
Marietta, Ga, US
I was camping at Talladega this weekend, I got there and several hours later a couple was setting up a tent next to me. Even though I wasn't running the generator I warned them that I would be running the HydroHot for hot water in the morning and it uses diesel to heat up the water, I did tell them I'd try to make sure they were up before I fired it up. They set up anyhow, so I looked it as "buyer beware" at that point.
Sonny, Anita and Phoebe
2005 Mountain Aire 4304
2005 F150 Crew Cab Toad
2009 Harley Ultra Classic
wny_pat
Western NYS
M GO BLUE wrote: 2oldman wrote: M GO BLUE wrote: I reserve the right to run my generator whenever I want and for whatever reason I want...period! Usually that works, but in cases of crowded spaces and no wind, generator exhaust can be not just stinky, but deadly.
Unless you have a Genturi like I do... and a diesel generator exhaust which is no where near as deadly as a gas generator. That was one of the main points of the OPs thread that you appear to have missed.
MRUSA
Wellington, FL
I have a Genturi too. It helps a lot, but it does not eliminate all of the fumes.
Marc, Wellington FL
2013 Entegra Anthem 44SL
2010 Lincoln MKT toad
Unified Tow Brake
Pressure Pro Tire Monitor
2oldman
Wilson Creek WA
wny_pat wrote: That was one of the main points of the OPs thread that you appear to have missed. I apparently missed that BLUE has one. Not feeling psychic today.
LongWeekends
Scottsdale, AZ
Don't you mean, "It is all about my generator!"?
Yeah, stupid I know but I could not resist.
Michael
Just me, my wife, our 11 year old daughter and our two big, hairy Goldens.
2004 Coachmen Cross Country
370DS - 300HP - 2 Slides
