RV.Net Open Roads Forum: Tech Issues: Slideout Problem
 > Slideout Problem
Grey Mountain
On the rez somewhere in Indian Country
Posted: 05/08/12 05:23am Link  |  Print  |  Notify Moderator
Got ready to depart a site and the driver's side front slide would not operate correctly. It would retract, but it sounded and looked like it was running over something every few inches. I could both hear and see this happen. I've inspected everything I can get to, but can't see anything obvious that could cause this type of problem.
Any suggestions?
GM
Discovery 39S Tin Teepee
Honda CR-V Toad
Jeep Cherokee Toad
Enrolled member of the Comanche Tribe
English Bride
Bichon Frise bear killers:
Lord Shonefeld von Reginald-Friese IV.
Lady Annabelle von Lichenstein-Friese III.
Jim Cindy
Northcentral, PA
Posted: 05/08/12 06:35am Link  |  Print  |  Notify Moderator
Sounds like you may have lost a tooth on the drive gear. See if can get to the motor and drive system and look the gears over carefully.
PBH Portable Beach House
2008 GMC 2500HD Duramax Allison
2009 Cameo 34CK3
MorRyde IS, Disc Brakes, G614's
PullRite Super Glide Hitch
Propane fueled Yamaha EF 2400is
Grey Mountain
Posted: 05/08/12 06:38am Link  |  Print  |  Notify Moderator
I'll take a close look at it today. Thanks for the suggestion.
GM
rhochnadel
Colorado
Posted: 05/08/12 07:54am Link  |  Print  |  Notify Moderator
If it is a Lippert slide out, go to the Lippert internet site and start reading the fixes for various problems. There is one field fix for a gear jumping the cogs because of too much play. Worked nicely on mine and not too difficult to perform. Good luck!
'05 Keystone Challenger TPK
'01 Chev 2500HD Duramax/Allison
Corgi "Pippin" & cat "Sundance"
ExRocketScientist
Laurel, MD
Posted: 05/08/12 10:21am Link  |  Print  |  Notify Moderator
Really need to know what type of slide system you have. My new TT has the Swintek system (the rights to which were bought out by Lippert) and the fourth time I operated it, the wires to one of the motors got jammed between the floor of the slideout and the main floor. Ripped a seal off of the wall in the process and almost pulled the wire out of the motor. Trailer is currently at dealer for repair under warrantee. There is all sorts of things I should be able to do with the motor controller on this thing in case I have problems, but that would only be with the first 12" of travel. Beyond that, you can't get to the slide controller because it is blocked by the slide.
Bad design twice over (location of controller and routing of wire).
ERS
Grey Mountain
Posted: 05/08/12 04:20pm Link  |  Print  |  Notify Moderator
How do I determine what kind of slide system I have? I have looked through all the information I have, but haven't found anything that describes the slides.
GM
ExRocketScientist
Laurel, MD
Posted: 05/09/12 04:43am Link  |  Print  |  Notify Moderator
Post some pictures of the mechanism. Someone will recognize it and be able to identify it.
Grey Mountain
Posted: 05/09/12 05:23am Link  |  Print  |  Notify Moderator
Gotta be smart enough to post pictures first...
GM
ExRocketScientist
Laurel, MD
Posted: 05/09/12 06:30am Link  |  Print  |  Notify Moderator
GM
There is a tutorial in the Forum Technical Support section.
Grey Mountain
Posted: 05/09/12 07:25am Link  |  Print  |  Notify Moderator
Just got a down-loadable manual from Fleetwood Customer Service. The slideouts are Power Gear.
GM
 > Slideout Problem
