M GO BLUE
Southgate, MI
OregonLuvr wrote: I have tried pushing the button to change to 50amp. It read 50 amp before. But now I am definitely only getting 30amp. It tripped my circuit breaker yesterday when I turned on my air, It was the air circuit breaker that tripped yet I still had AC. I am plugged in with the correct 50amp plug. I have had to use my adapter before so I do know I am plugged in correctly.
I am thinking it is an issue with the campsite electric. I am going to check it out with the owners today. Maybe ask some of my fellow campers what they are getting. Just never had this problem before.
Does the above in black tell us that you are using an adapter such as a 50A to 30A adapter to plug into the campground pedestal? If so you may only have 30A service going into your coach...
2005 Chevy Silverado 3500 dually CC/LB Duramax/Allison
2008 Jayco Designer 35RLTS fifth wheel
Onan 5500W Marquis Gold gas generator (HGJAB - 1038D)
MICHIGAN RALLY - July 19-21, 2013 Click here
wolfe10
hughesjm21 wrote: Ask campground to measure volts between the two hot legs. If it is 0 volts then they have a problem not you. We stayed in park that was wired wrong.
CORRECT. Whether the CG guy does it, or you ask a fellow camper if they have a voltmeter and would mind helping you for 2 minutes, this will very quickly tell you if there is a problem with the CG wiring of the 50 amp circuit.
Outer straight (hot) to outer straight (hot)= 240 VAC if wired properly. 0 if wired improperly (both hots on same "side" of CG breaker box).
Either outer straight (hot) to center straight (neutral)= 120 VAC
Either outer straight (hot) to center round (ground)= 120 VAC
Center straight (neutral) to center round (ground)= 0 VAC
If all OK, the issue IS with your coach.
Brett Wolfe
1997 Safari Sahara 3540
EX: 1993 Foretravel 36' U-240
rvrepairnut
bc
vtbigdog wrote: If the 30A LED is displayed on your Control Panel, you may need to press the button below the display to change the LED to 50A.
Let us know if this corrects the issue.
2ndhom
Eugene, Oregon
wolfe10 wrote: hughesjm21 wrote: Ask campground to measure volts between the two hot legs. If it is 0 volts then they have a problem not you. We stayed in park that was wired wrong.
Excellent suggestion!!!
OregonLuvr
Talent, Oregon
M GO BLUE wrote: OregonLuvr wrote: I have tried pushing the button to change to 50amp. It read 50 amp before. But now I am definitely only getting 30amp. It tripped my circuit breaker yesterday when I turned on my air, It was the air circuit breaker that tripped yet I still had AC. I am plugged in with the correct 50amp plug. I have had to use my adapter before so I do know I am plugged in correctly.
NO I am not using the adaptor.
Karen
2007 Winnebago 35A
2010 Chevy Equinox
Proud Member of Open Road Singles http://www.openroadssingles.com/
OregonLuvr
Talent, Oregon
OK going to have them check the pedestal BEFORE I assume its my coach. Also going to reset the elec first.....sigh
I can run on 30 but dang I am paying 50amp prices
ArchHoagland
Clovis, CA, USA
Did it ever work correctly at this campsite?
Would it be difficult to move to another site just to test it?
Are any of your neighbors having a similar problem?
And last....have you gone to see any plays?
2004 Monaco La Palma 36DBD
Workhorse W22 8.1 Gas Allison 1000, 7.1 mpg
US Gear Brakes
Nothing is either good or bad, but thinking makes it so.
M GO BLUE
Southgate, MI
May not be a stupid suggestion but I assume you are plugged into the camground pedestal with the 4 prongs (i.e. 50A)...
Are the circuit breaker(s) on the camground pedestal all turned on?
OregonLuvr
Talent, Oregon
OK update. I switched off the breaker and unplugged, then plugged back in, switched on the breaker. Watched my surge protector, Line 1 is ok...Line 2 is not. Yes I have had 50amp at this site until yesterday.
Told the campground worker, and he is going to have the owner come over and check it...NOT my coach YIPPEE Said it might be the plug. SO is going to fix it or have their electric company come out and fix it.
I appreciate all your suggestions. It helped me track down the issue.
No I havent seen any plays lately HA HA I am a Travel Nurse and have been gone for the past 4 years working. I only get home for a week at a time about every 6 weeks so no real time. I have seen some of the plays in the past but not recently. I am working up in the Salem area right now so have gotten home a little more frequently. I am taking the summer off (WAHOO) so maybe will have more time. Altho Camping is on my list of things to do. There is a big difference for me from Living in MH, to camping. I pack all different stuff for camping ie: blender, Mudslide mix, BBQ ha ha instead of laptop, IPAD, stethoscope ha ha
thanks again everyone
vtbigdog
VT, GA
It may only be the breaker...
Richard
2003 Safari Trek 3011
8.1 Workhorse/Allison
