RV.Net Open Roads Forum: Newbie need advise for the length of TT
 > Newbie need advise for the length of TT
Rich08
BC
Posted: 05/08/12 09:51pm Link  |  Print  |  Notify Moderator
I want to buy a Denali 289RK TT. The overall length is 33'8".The unloaded weight is 7442lb.
A lot of people say it is too long. It is more than 50' including the truck. It is hard to turn around the corner, to backup into the campsite, to gas station and Grocery store.I tow with a Ford F150 ecoboost with Max towing package.
Thanks!
trike2
idaho
Posted: 05/08/12 10:01pm Link  |  Print  |  Notify Moderator
I agree, it is a little long. My 29ft is hard to find a place to park in some campgrounds, depending on your choise, mine is forest land and private, some of the older ones are not capable of handling long units they build today. I have to back into some areas, then un hook, park my truck behind it. The fornt end does protroude beyond the site at time. Also are you sure the truck can pull with the unit loaded?
2005 gmc 3/4 hd, sb, 4x4, 8.1 gas/allison 17,000 and climbing.
2005 Lakota, by Monaco, 3 slds, 29f.
Sandia Man
Rio Rancho, NM
Posted: 05/08/12 10:27pm Link  |  Print  |  Notify Moderator
We pull a 32' 10K lb TT with 3/4 ton crewcab gasser and don't have any problems getting around town or in and out of gas stations, but it does take some getting used to. We always manage to find spots in State, Federal, and COE parks, but we plan ahead when staying at these facilities and arrive or reserve early. Private parks will normally have spaces for the large rigs so that isn't much of an issue. If that's the rig/floorplan you want and your TV is capable, go for it and enjoy. Just start out slow and easy and you will get the hang of it quickly. Having a high quality, properly installed WD hitch will give you a smooth, balanced towing experience so you don't feel overwhelmed and out of control. Happy Camping!!!
samsontdog
Oregon, Wash Coast summer, Yuma Az winter
Posted: 05/08/12 11:05pm Link  |  Print  |  Notify Moderator
I went from towing a 28ft TT to a 34 ft TT with very few problems other than some camping sites that I no longer fit in. Really like the extra room that the 34 ft has. Would not go smaller
samsontdog
Tvov
CT
Posted: 05/09/12 05:22am Link  |  Print  |  Notify Moderator
Have you ever towed a trailer before?
2008 F-250 CrewCab 5.4L,
autorot8
N. CA
Posted: 05/09/12 06:49am Link  |  Print  |  Notify Moderator
I'm 60' total length and really have not had any issues towing or finding a campsite.
F-350 towing a Prime Time Lacrosse 296BHS
"Overstating the Obvious rarely helps the Oblivious!"
mpfireman
Cook County Il
Posted: 05/09/12 08:37am Link  |  Print  |  Notify Moderator
You do realize that with that trailer, fully loaded, it will weigh about 2 thousand pounds more than your TV. Sometimes we are asking to much from our TV, even though it is rated to tow or haul that much.
Many of the state and federal parks have trailer length limits, but in canada that might be different.
1998.5 Dodge Ram Quad Cab Cummins
1998 Sunnybrook 27RKFS Fiver
phenrichs
Sioux Falls, SD
Posted: 05/09/12 08:48am Link  |  Print  |  Notify Moderator
You just need practice. Don't let anyone else influence what you like. We went from a 20ft HTT to a 35ft 2 slide TT. It is HUGE. I get it around no problem.
Can I get gas anywhere I want? No.
Can I camp anywhere? No.
Would I go back? No.
You simply adjust. You will learn to reserve earlier than you used to. You learn to call ahead and make sure that you will fit in the spot they claim is big enough on their website or brochure. You might drive around the block once or twice to find the right fueling station that will accommodate your rig.
These are little things in comparison to being happy with the overall experience. Once you get it. Just take a day and hook it up and drive around. Find a big mall or other parking lot and practice. If your wife will be helping to guide you into a space take her along to practice.
2006 Ram 3500 Megacab Cummins
2012 Keystone Sprinter 311BHS
rfryer
Phoenix
Posted: 05/09/12 09:38am Link  |  Print  |  Notify Moderator
Too big for some, not so for others. You trade maneuverability for space parked. It's not too big if you primarily stay in commercial parks, don't mind structuring your trips with advance reservations to be sure you can get a spot, and recognize you'll have limitations where you can stop for gas and so on.
It's too big if you want to camp on some public lands like national parks, forests and state parks. You'll be able to get in some, but many will be off limits. There's simply far more sites that fit smaller TT's than large ones. You'd be able to boondock on public land if you stay close to the pavement and avoid unimproved roads, but no many people buy that big a rig to boondock.
JKQ
Posted: 05/09/12 09:48am Link  |  Print  |  Notify Moderator
A previous post said too big for some but not for others. I'm a total of 56'9" & have yet to have a problem. I usually get a pull through campsite but I will back in if necessary. I always refuel at truck stops & on many occasions have parked at a Wendy's or Crackerbarel for lunch, always being aware of how I'm going to exit. A little planning & common sence is all you need.
2013 CruiserRv Enterra 314 RES TT, 36ft, 3 slides
2013 Ford F250 Crew Cab Power Stroke Diesel 4x4
Reese WD hitch with dual friction control bars
Dometic 3000 KW portable genset
