RV.Net Open Roads Forum: Hybrid Travel Trailers: A/C unit on 2004 21SS0
Open Roads Forum  >  Hybrid Travel Trailers
 > A/C unit on 2004 21SS0
TheMonty's
New hampshire
Posted: 05/09/12 07:45am Link  |  Print  |  Notify Moderator
So I've had the camper since 2005 (bought new). Never really used the A/C. Problem is, now that i want sell the camper, the A/c doesnt work at all. Camper is plugged into house power. Nothing, no fan, nothing. Checked the fuses on the fuse panel, everything looks normal. Not sure if battery needs to be connected in order to get anything. Haven't tried that yet.
Any ideas? I am sure they will charge me a fortune at the Rv center to diagnose.
1995brave
San Antonio, TX
Posted: 05/09/12 08:33am Link  |  Print  |  Notify Moderator
Make sure the circuit breakers are on. Does your unit have the A/C thermostat on the wall? If so you need the 12 volts to power it.
Chuck_S
Broadview Hts, OH, USA
Posted: 05/09/12 06:01pm Link  |  Print  |  Notify Moderator
Yep, the AC unit should be on it's own 20a circuit breaker in the power box. Cycle it a couple of times. This probably has a twist knob on the unit itself rather than a thermostat so exercise those as well. Should be able to remove the ceiling panel and check the wiring. Wiring diagram will be on line on the manufacturer's (not the trailer maker) web site.
-- Chuck
'06 Roo 23SS behind '07 Expedition out of Cleveland
Our Photo pages
mbopp
Henrietta, NY, USA
Posted: 05/09/12 06:18pm Link  |  Print  |  Notify Moderator
I had to have the AC fan replaced on my '05 21SSO (warranty.) IIRR a few people had their fans replaced, it may have been a bad batch of fans / bearings.
You can try getting on the roof, removing the A/C cover, and see if the fan turns over by hand (power off!)
2013 North Trail 21FBS
2012 F-150 XLT Ecoboost ("EcoBeast") scab
mdcamping
Willington, CT
Posted: 05/09/12 08:29pm Link  |  Print  |  Notify Moderator
I agree, Sounds like a power problem, slowly cycle the fan switches & t-stat, listen for any humming noise or dimming of any lights in the trailer...if nothing, theres a good chance its either a breaker or broken wire/switch in the A/C unit.
Good Luck,
Mike
2007 Toyota Tacoma, Double Cab 4x4 Max Towing 6,500lbs GCWR 11,100lbs
2011 Jayco X20E, Pro Series 800lb Weight Distributing Hitch
Husky Sway Control Bar, Prodigy Electronic Brake Control
McKesh Mirrors
States we've camped in so far...
RoyB
King George, VA
Posted: 05/11/12 04:23pm Link  |  Print  |  Notify Moderator
Be sure to check the 12VDC requirement. I noticed you had battery questions early on in your post list. The 12VDC requirement for the T-stat should work from the 12VDC coming from your converter/charger unit and/or the battery.
Make sure you are in A/C mode and not heat mode.
When checking the A/C circuit breaker might be a good idea to turn it off and hold all the way down for reset then turn it back on. Sometimes they will be tripped and doesnt look like it is...
ALso if you are using a 15A/20A garage 120VAC circuit to run your trailer be sure the 120VAC is in the proper "green scale" range for running the A/C.
Just thinking out loud here....
Roy and Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
POPUP PHOTOs-Pg52-Pg56
Gaffer222
Northwestern CT
Posted: 05/11/12 05:47pm Link  |  Print  |  Notify Moderator
If the AC was never run the fan may be seized up. Take the cover off and see if you can spin the fan by hand. Mine worked once I gave it a spin.
2007 Ford Expedition Limited w/Tow package & 3.73 Rear end
Equalizer & Prodigy
2005 EZ190 Keystone Zeppelin HTT
DW, DD Circa 2002, DD Circa 2005
My Webshots
