RV.Net Open Roads Forum: Fifth-Wheels: Help! 245/75/16 on 16x6.5 trailer wheel???
 > Help! 245/75/16 on 16x6.5 trailer wheel???
07PSDCREW
Berlin Ma
Posted: 05/14/12 08:42am Link  |  Print  |  Notify Moderator
Does anyone know if this will work? Thanks.
2007 Ford F350 6.0 CC SB
Fully bulletproofed/EGR/ARP Studs
Reese 16k round tube slider hitch.
2000 Damon Hornet 2850BH 5er
Days camped 2011= 34 2012= 46
Ed9824v
Agua Dulce, Calif. 70 mi S.E. of Los Angeles
Posted: 05/14/12 09:27am Link  |  Print  |  Notify Moderator
that is the tire size on my 2000 sea breeze but not sure of the wheel width. ED
Ed So.Calif
1950 Ford F1 street rod
1968 Baha Bug with 2.2 ecotec motor 170 hp, kingcoil
2000 National Sea Breeze 5th wheel trailer
1998.5 Dodge 2500 4x4 Cummins,4.10 gears,turbo,trans,injectors,oil cooler,lockers,edge EZ, 35" BFG's, air dog lift pump etc.
Snow_King
Gold Canyon, AZ
Posted: 05/14/12 09:31am Link  |  Print  |  Notify Moderator
Spec's for LT245/75R16's call for 6.5 to 8" rims. So Yes!
Somewhere in a Fifth Wheel - Where it does not Snow
07PSDCREW
Berlin Ma
Posted: 05/14/12 09:41am Link  |  Print  |  Notify Moderator
Awesome. Thanks for that!
Splashers3
Oakville, MD
Posted: 05/14/12 10:07am Link  |  Print  |  Notify Moderator
The tire and wheel sizes the OP listed are the exact sizes on my GMC 2500....so, yes, they will work fine from the tire mounting to the wheel.
2008 GMC Sierra C/C 2500HD D/A - w/Titan 52Gal tank
Ride Rite Airbags, Trail Air Pin Box, Garmin Nuvi 1450LMT,
Blue Ox Bed Saver, TST Tire Monitor, Yamaha EF2000is,
2009 Cedar Creek Silverback, GII, 32 WRL w/ XPS RIBS
07PSDCREW
Berlin Ma
Posted: 05/14/12 10:39am Link  |  Print  |  Notify Moderator
Thanks again! I came across a deal on some white steel trailer wheels for 150$ practically brand new. I've had the new tires on standby till I got rims. They are 3100lb rated at 90 psi.
gkainz
Arvada, CO, USA
Posted: 05/14/12 03:41pm Link  |  Print  |  Notify Moderator
but one caveat - don't wheels have a max working pressure stamped on (or inside) them somewhere?
'97 Dodge 2500 CTD 4x4
'10 Keystone Laredo 245 5er
Snow_King
Gold Canyon, AZ
Posted: 05/14/12 04:26pm Link  |  Print  |  Notify Moderator
90 psi is not a pressure rating?
whiskyrunner
Oconto Wisconsin
Posted: 05/14/12 06:03pm Link  |  Print  |  Notify Moderator
Yes SnowKing, 90psi is a pressure rating, but for the tire not the rim,,, I do believe the rims wil only be rated for 80 psi.OP says in 3rd post he has had tires on standby until he found rims,tires are 3100lbs @90 psi,
2000 Ford F250,4x4 diesel short box,Firestone airbags
2004 Terry Quantum 36ft fiver,4 slides
Snow_King
Gold Canyon, AZ
Posted: 05/14/12 06:07pm Link  |  Print  |  Notify Moderator
Well I believe he is referring to the wheels, as I have never heard of a tire rated at 3100 at 90!!!!
Title includes 245/75R16 which is a standard LT tire size rated to 3042 at 80 for a LRE.
* This post was edited 05/14/12 06:20pm by Snow_King *
