RV.Net Open Roads Forum: Travel Trailers: Question about Furnace
 > Question about Furnace
jhocksrule
Topeka
Posted: 05/14/12 01:37pm Link  |  Print  |  Notify Moderator
I camped this past weekend and it got a little cool in the night. I turned on my furnace. My question is should my fan for my ducted air conditioner unit be running at the same time as my furnace??? The heat would kick off and on and the fan of the AC ran all the time. Is that normal. Thanks
chuckfwatson
Western North Carolina
Posted: 05/14/12 01:52pm Link  |  Print  |  Notify Moderator
Mine will do the same thing. On my thermostat, you can select 3 modes, Fan, Heat or A/C. If your mode is on fan it will run with the furnace on or off. Your thermostat should have the option to turn the fan off, I think mine actually is displayed as AUX ON or AUX OFF.
Hope this helped.
bartlettj
Forest Grove, OR
Posted: 05/14/12 01:53pm Link  |  Print  |  Notify Moderator
If you have the Dometic digital thermostat, the A/C fan is controlled by the "fan" setting. If you want the A/C fan to come on, click the mode to "fan" and set it to "lo" or "hi". If you don't, set it to "Au" for Auto.
Bit Bucket
Brookings, Oregon
Posted: 05/14/12 02:52pm Link  |  Print  |  Notify Moderator
Ditto here...
This gives you the option of using your AC blower with your furnace blower, or not, at your choice. You should have got a little booklet with your thermostat, if not, I would bet you can find a copy of it online.
JJBIRISH
Butler, PA, USA
Posted: 05/14/12 02:55pm Link  |  Print  |  Notify Moderator
No it isn’t normal for the AC to run while the furnace is running…
Love my mass produced, entry level, built by Lazy American Workers, Hornet
Bit Bucket
Brookings, Oregon
Posted: 05/14/12 03:08pm Link  |  Print  |  Notify Moderator
It is normal for the newer digital thermostats to have that feature.
He said the fan for the AC was running, not the compressor.
It can be set up this way to circulate a LOT of air quickly. When we boondock while hunting we sometimes use this feature to quickly dry clothes on a rack.
If one doesn't like it, it is easy to turn it off.
If one likes it, it is easy to turn on.
The best of both worlds, the user can set it up however they want!
ScottG
Bothell Wa.
Posted: 05/14/12 03:17pm Link  |  Print  |  Notify Moderator
Turn the fan to "Auto" and only the furnace will run when the T-stat is set to heat.
Scott, Grace and Wesly
H0NDA eu2000i
