RV.Net Open Roads Forum: Biggest New 5er behind my '06 Dodge 2500?
Search only in Tow Vehicles
 > Biggest New 5er behind my '06 Dodge 2500?
Page of 5
Chiefcpo
Huntsville, Alabama
Posted: 05/15/12 07:52pm Link  |  Print  |  Notify Moderator
YES you can pull with anything you want to!!!!! Just let me know where you are so I can stay a long safety distance from you.
Just weighed my 2012 3625re Big Sky with 4 slides and even my 2011 F350 is over loaded!!!
Trailer loaded for camping 14400 pin weight 2940 ( need to move some to the back I know)
F350 s/a 5360 d/a 7380 loaded s/a 5340 d/a 4440 unloaded total weight 9780
with f/w s/a 5360 d/a 7380 trailer axle 11440 total 24180
nuff said!!!
Chiefcpo
Huntsville, Alabama
Posted: 05/15/12 07:57pm Link  |  Print  |  Notify Moderator
P>S> F350 LB, drw, cc, 6.7 diesel, 50 gal. transfer flow, Lariat package.
Keystone Big Sky, 4 slides, 2012 loaded,
Wife, 2 Fur Babies, full of fuel and loaded for camping and did move weight but still over weight but not on the pin.
jayhardy
Washington
Posted: 05/15/12 08:26pm Link  |  Print  |  Notify Moderator
I love the input to my question--And I can't wait to here the responses to this question--I will willing admit that I am not a truck quy so probably a silly question but I'll ask it anyhow--Why does my 2006 Dodge Ram 2500 Plus cab-short bed weigh any different than anyone elses?????? Aren't we talking minimal weigh differneces???
kaydeejay
SE Michigan, USA
Posted: 05/15/12 08:31pm Link  |  Print  |  Notify Moderator
cabanaman wrote:
I've been coast to coast with no problem towing my 40' 4 slide 5er with my 2500.
Just because you are doing it does not make it right!
Look at the following post from Ricochet (posted 5/9/12).
I'd say you are firmly in the #3 category.
ricochet wrote:
"Having said that you are always going to have 3 types of folks towing.
1 is the GVWR guys who use the safety ratings set forth by the manufacture. I'm one of them.
2 is the RAWR guys who stay under the rear axle ratings which is most likely the same as your tire ratings. Logic is its legal in most states.
3 is the guys who don't believe in ratings period and would tow a Grand Teton with whatever they happened to own.
Just me but 3k pin is where I draw the line between the SRW and DRW trucks. Although the last couple of years the SRW 35 series trucks have made some big gains in payloads due to the bigger wheels and tires.
Good luck with your decision.
Keith J.
1999 Sunnybrook 27RKFS Fiver.
2005 GMC Sierra 2500HD CC/SB/DA 2WD, LBZ air cleaner, 52 gal Titan tank, Bilsteins, Line-X, Westin steps, Prodigy, Retrax cover, 16K Superglide, 5th-Airborne pin-box, Multi-vex mirrors, TST TPMS.
kaydeejay
SE Michigan, USA
Posted: 05/15/12 08:36pm Link  |  Print  |  Notify Moderator
I can't answer that except...........
- Gas vs diesel - around 700#
- 2WD vs 4WD - maybe 400#
- Plus cab vs Mega cab - maybe 300#
- 5'6" bed vs 8' bed - another 300#
All out of the same GVWR.
Maybe you can now answer your own question
jayhardy
Washington
Posted: 05/15/12 08:43pm Link  |  Print  |  Notify Moderator
Thank you
Diesel
4WD
mega cab
Short bed
Snow_King
Gold Canyon, AZ
Posted: 05/15/12 08:54pm Link  |  Print  |  Notify Moderator
jayhardy wrote:
Thank you
Diesel
4WD
mega cab
Short bed
Oh no! Mega cab! I missed that when I looked at the picture of your rig. The Dodge Mega cab has lousy tow numbers. I have to retract my earlier post about weights.
Here is the issue, the curb weight is 7331 so you will weigh around 7800 pounds ready to tow, leaving 1200 pounds for pin weight. Rear axle is a couple hundred pounds heavier cutting into pin weight if you disregard the GVWR.
Better stay with what you have now.
* This post was edited 05/15/12 09:10pm by Snow_King *
Somewhere in a Fifth Wheel - Where it does not Snow
jayhardy
Washington
Posted: 05/15/12 09:03pm Link  |  Print  |  Notify Moderator
Sorry--I meant to say Plus Cab- I wont quote you on your earlier POSTS. No need to retract your comments. It ain't "Law & Order". It's RVing!!!! Thanks for all your thoughts
Al B
Cowtown
Posted: 05/15/12 09:15pm Link  |  Print  |  Notify Moderator
X2 nlscooby The only difference between 2500 and 3500 is the overload and the "3"
nlscooby wrote:
Dusty,
With all due respect, you are incorrect here. I have owned several Dodge Cummins trucks (both 3/4 ton and 1 ton trucks). My truck was available as a 3/4 ton and 1 ton version with (literally) the ONLY difference being the rear overload springs (oh, and the "3" instead of the "2" just before the _500 on the door!)
Perhaps you are thinking of 1/2 ton trucks versus 3/4 ton and 1 tons?
1/2 tons are quite different!
Cummins Powered
Snow_King
Gold Canyon, AZ
Posted: 05/15/12 09:51pm Link  |  Print  |  Notify Moderator
OK, got it! Quad Cab, not Mega! That is much better!
Page of 5
