Was hoping that someone could help me with directions on the water heater.
I have been trying to light the pilot and no luck.
I made sure that the propane is on, I move the switch to pilot then I light the lighter and try to light the piolot. Nothing.
Is there something that I am missing.
This is our first camper
Layton lite 2005
I light the oven and stove no problems
The heat and ac work great
Just this heater thing uuuggggghhhh
hi
new to this forum and very excited to ask ton of questions. But i just purchased a layton lite travel trailer. It has 2 propane tanks. Can I go thru tunnells with them?
Turn to pilot - Press down - Light and hold down for about 30 seconds. There is a thermocouple that is a safety feature. The thermocouple has to heat up. If it is not hot, it won't allow the burner to come on.
When the pilot will stay lit - turn to on.
If you still have no gas flow you may have a spider web or something blocking the orafice, Usually a paper clip or needle will clear it out. Spiders make webs inside burner tubes and sometimes need brushing out.
