RV.Net Open Roads Forum: Class A Motorhomes: Beaver queen bed question
 > Beaver queen bed question
lj2654
weeki wachee, florida
Posted: 05/15/12 12:54pm Link  |  Print  |  Notify Moderator
I have a 2001 Beaver Contessa DP. The question I have is about the queen bed....I know you can raise the rear of the bed for underneath water lines and access to floor area...On the aft part of bed frame there are 2 brackets that have rollers on them. I dont know if they are there to lift the bed or support the bed when raised up...it is very difficult to raise end of bed up as its very heavy....takes two of us to raise it.......also there is a panel aft of bed with 2 rubber hooks, I assume is access to motor?
Can you tell its new to me yet?
2001 Beaver Contessa Naples 40
2005 Honda CRV Toad
retired AirForce
answerswillvary
eastern washington
Posted: 05/15/12 01:30pm Link  |  Print  |  Notify Moderator
Moved from RV Parks, National Parks, State Campgrounds & More
2009 Tiffin Allegro Bus 43QBP
docj
Fulltime--Home is where we park it
Posted: 05/15/12 02:26pm Link  |  Print  |  Notify Moderator
If your Contessa is similar to our Patriot, the rollers are there to let the bed move when the slide is extended. Yes, the bed is very heavy and hard to raise; we prop it in place with a piece of wood if we need to work under it. Fortunately there is little reason to lift it unless there is an issue with the slide. The "trap door" on the floor by the bed is for access to the engine compartment; in our coach the bed has to be raised before the trap door can be opened--not a good design.
Sandie & Joel
2000 40' Beaver Patriot Thunder Princeton--425 HP/1550 ft-lbs CAT C-12
2009 Chevy Malibu LTZ with ReadyBrute tow bar/braking system
Official WiFiRanger Ambassador WFRAMB303
Follow our adventures on Facebook at Weiss Travels
lj2654
Posted: 05/15/12 03:10pm Link  |  Print  |  Notify Moderator
Thanks for the info...sounds as though they are about the same as design goes....I thought there was access to engine under bed too...but no, just the access panel aft of the bed,and it has to be raised to get panel off.....I agree(design issue)
thanks again and My wife and I enjoy your travel stories and pictures!
bkd148
Spanaway, WA.
Posted: 05/15/12 03:52pm Link  |  Print  |  Notify Moderator
If you had a north/south bed design (no slide) there would be access to the engine by just lifting the bed. Because you have a slide, the builder (Beaver) has to isolate the engine in another way, ie the box with seperate access panel. It would be a nightmare to seal it from noise and dirt any other way. Yes raising the bed is a pain but in the five years I've owned my Beaver I think I've raised it maybe 5 times. I see no or have had no problems with the design.
Marty
2002 Beaver Patriot Thunder
Cat C-12 455hp. 6spd. Allison
2002 Jeep Wrangler Sahara
docj
Posted: 05/15/12 05:47pm Link  |  Print  |  Notify Moderator
We recently discovered that the closet floor is also an access to the engine compartment. It's hard to tell from inside, but from the engine area you can easily see it. Of course, clearing everything out of the carpet to remove the panel is worse than lifting the bed! LOL
