RV.Net Open Roads Forum: Towing: BD Diesel varible vane exhaust brake
Search only in Towing
Open Roads Forum  >  Towing
 > BD Diesel varible vane exhaust brake
firecaptain59
Modesto
Posted: 05/15/12 05:51pm Link  |  Print  |  Notify Moderator
Ok all the Chevy owners out here has anyone installed one on their truck. I've looked at the Banks Speed Brake and the BD Diesel brake. I like the price of the BD Diesel. I'm looking for someone that has used the BD Diesel before and their thoughts
seattlefirervr
Snohomish, WA
Posted: 05/15/12 07:36pm Link  |  Print  |  Notify Moderator
Cap,
Not a Chevy owner, but my BD Brake for my Ford has been more than satisfying. I have an older pickup (2000) but it is the best safe, secure, reduced pucker factor, etc... $$ that I have ever spent over ANY add-on for my truck.
2006 31' Wildcat QBH,Yamaha 3000EFi Generator
2000 Ford F250 Lariat PSD CC,SB,4WD,AT. aFe Megacannon Airfilter,4" Diamond I exhaust,Custom"Evergreen Diesel"chip,Autometer pillar gauges,BD Torque Converter,ATS Turbo Housing,Wicked Wheel,BD Exhaust Brake,
Splashers3
Oakville, MD
Posted: 05/16/12 02:44am Link  |  Print  |  Notify Moderator
I'd be interested in folks responses to this topic as well. I would like to do the same.
Seattlefirervr - who did the installation?
2008 GMC Sierra C/C 2500HD D/A - w/Titan 52Gal tank
Ride Rite Airbags, Trail Air Pin Box, Garmin Nuvi 1450LMT,
Blue Ox Bed Saver, TST Tire Monitor, Yamaha EF2000is,
2009 Cedar Creek Silverback, GII, 32 WRL w/ XPS RIBS
Lantley
Ellicott City, Maryland
Posted: 05/16/12 04:28am Link  |  Print  |  Notify Moderator
I was going to go that route however I was refereed to Killerbee Performance.( a forum member) He created a tune that made a speed brake (exhaust brake) via software. It required a new ECM that I installed myself. (very simple plug play)
Bottom line I now have a exhaust brake that works very well and was half the price of the Banks Speed brake. Basically he reprogrammed the trucks computer to activate exhaust brake without installing after market equipment Killerbee's tune works and performs like a Banks speed brake.
07'Duramax dually,12'Open Range 399BHS
Hawkshead TPMS,Hensley BD3,Killerbee exhaust brake
Blue Ox Bedsaver,air bags w/compressor
Arvika pin box bike rack,Bak Flip tonneau cover
5500 Onan LP,EMS-HW-50
14'Porta Bote w/8.0 Nissan
Vu Cube 2000,Splendide 2000S
ronfisherman
SE Michigan
Posted: 05/16/12 06:20am Link  |  Print  |  Notify Moderator
Fleece Performance also has one. Several after market EFI LIVE programmers like the one mentioned above can do this programing.
Here is a thread from DP on the subject. Banks Speed Brake on a 2006 LBZ Dually
GM's Medium Duty Trucks with Duramax engine have had this option in them since 2006 model year.
Kodiak Chassis Class C Forum
bob213
Fresno, CA
Posted: 05/16/12 10:47am Link  |  Print  |  Notify Moderator
Reprogramming the ECM is the easiest way to go. The person programming it can write a tune specific to your needs. Killerbee fixes the DIC so it shows true MPG, adds the exhaust brake etc. You can set up a switch to toggle between several tunes and always have your stock tune to go back to if you need to pass a smog test in certain states. I prefer KillerBee, but there are others out there with great skills. IdahoRob on the the diesel forums is a standout also.
firecaptain59
Modesto
Posted: 05/16/12 12:40pm Link  |  Print  |  Notify Moderator
Roughly how much did it cost to go that route
jims1
NC
Posted: 05/16/12 02:16pm Link  |  Print  |  Notify Moderator
What year is your truck? The earlier duramax engines didn't have the variable vain turbos.
Pacbrake is another exhaust brake.
'06 Ram with a Cummins
Tuned w/ EFI-Live
'09 36MAX1 Carrilite
Me, Alie, and Salie
firecaptain59
Modesto
Posted: 05/16/12 02:21pm Link  |  Print  |  Notify Moderator
2007.5 with LMM
Lantley
Posted: 05/16/12 02:27pm Link  |  Print  |  Notify Moderator
It could have been as cheap as $399.00 For an exhaust brake only tune.
I kept my old ECM (Electronic Control Module) vs. returning it for a core charge refund.($300.00 credit upon return) I also had a single stage tune 499.00 vs 399.00 for exhaust brake only tune.
So I paid $799.00 total. I can still return my original ECM for a partial refund and reduce that figure $200.00 or so.
$399.99 is what you can pay a tuner to create a ECM speed brake for you.
I had my tune created by Killerbee Performance
