fla-gypsy
North Florida
I carry a 6 ton for my 10K GVWR trailer and wished it was bigger. Next time I will buy a twelve ton just because bigger is better sometimes.
mobilcastle
OH
fla-gypsy wrote: I carry a 6 ton for my 10K GVWR trailer and wished it was bigger. Next time I will buy a twelve ton just because bigger is better sometimes. X2-I like heavy duty.
2010 Heartland 3670RL Demco,dual panes,2-AC,
7000lb axles,G rated LT tires,38' high profile,
2011 Chevy 3500HD,Dually,D/A,LB,EB,4X4,
B&W Companion,GVWR-13,000
Tango, AE7UI
Taylorsville, UT
I have a 12 ton and I bought this size for the extra lift (height) range.
2007 Tango 2660RKS Fifth Wheel, 2006 Chevy D/A 3500 with service body,
JIMNLIN
out here
I have a old '70s 12 ton shortie hyd bottle jack. It was sold as a truckers special as it came with a 12" x 12" wide base for using on soft surfaces on the side of the road. Its great for sliding under the axles to lift the axle when changing a flat tire.
Lifting one side of the trailer is no problems with this jack.
IMO a 4000 lb jack is simply not he best tool for your 16000 lb trailer when lifting the end of one axle or other jobs that require lifting the side of the trailer.
'97 Park Avanue 28' 5er 11200 gvwr two slides
Rock2
PA
Wow I got lot of response. That is what I like about this forum. Okay I just only need a bottle jack to lift up one side of tire so that I can work on bearing or just in case if tire gets flat on the road. So you are saying 2 ton bottle jack is not enough?
mtlroofer
ok
check out http://www.gotrailerpal.com/
i just used one recently and it worked GREAT! no jack, no fuss.
looking at running them for our entire company fleet.
more expensive than a jack, but MUCH safer also.
feel free to pm me if u have any ?'s
doss
BigT
Texas Panhandle
Or get a trailer with a Big Foot or a similar hydraulic lift system and leave the bottle jack and trailer aide stuff at home.
2012 Hitchhiker Discover America 349 RSB
Bigfoot levelers, Tailgater satellite
2011 Ford F350 PSD, Pullrite Superglide
RDS Toolbox Tank Combo, Garmin GPS & an itch to hit the road
laknox
Arizona
BigT wrote: Or get a trailer with a Big Foot or a similar hydraulic lift system and leave the bottle jack and trailer aide stuff at home.
Until it malfunctions. :-) Even if I had a leveling system, I'd still carry a jack.
Lyle
1936 John Deere Model A
Allworth
Orlando, FL
Is Big T suggesting a $2500 replacement for a $19 bottle jack?
(Stop by Northern Tool)
Formerly posting as "littleblackdog"
Martha, Allen, & Blackjack
2006 Chevy 3500 D/A LB SRW, RVND 7710
2008 Titanium 30E35SA; EZ-Lube axles; wet bolts; spring hanger gussetts; BFG Commercial TAs
"Real Trucks Don't Have Sparkplugs"
07PSDCREW
Berlin Ma
I have no problem using the factory bottle jack that came with my F350. I just used it with a single piece of flat wood to jack my fver onto (4) 6k jackstands so I could install my new 16's.
2007 Ford F350 6.0 CC SB
Fully bulletproofed/EGR/ARP Studs
Reese 16k round tube slider hitch.
2000 Damon Hornet 2850BH 5er
Days camped 2011= 34 2012= 46
