pianotuna
Regina, SK, Canada
Hi Mr. Wizard,
Any estimate of the finally bill? And was the cause loss of coolant? Or did the coolant get "expelled" because of some other failure?
Regards, Don
Kustom Koach Class C 28'5" 256 watts Unisolar, 875 amp hours in two battery banks 12 volt batteries, 2500 MSW watt inverter.
Mr.Mark
California/Tennessee
MrWizard wrote: the damage to the engine was considerable but is Not catastrophic
Turbo OK
head OK
its getting six new pistons 0.012 over size , no sleeving needed
new rod bearings etc..
the machine work "reaming/honing" has been completed
parts won't arrive until Tuesday
hopefully back on the road by next Friday
Somewhat good news! I guess the other shop was/is living up to their reputation...gouging!
Any news on the estimate?
MM.
Mr.Mark
2008 Monaco Dynasty, 42.2 ft., 4 slides, 425 hp clean-air Cummins diesel
2013 Honda CR-V EXL, AWD, w/Nav, SMI Air Force One vacuum-assisted braking
CA Traveler
The Western States
What causes 6 pistons to lose compression and apparently no metal parts damage the head or turbo? Were the pistons burned through the top?
2009 Holiday Rambler 42 Scepter with ISL 400 Cummins
2004 Honda CR-V
Bob
Lady Fitzgerald
Tempe, AZ, USA, Earth
Turbo OK
head OK
That sure is a far cry from complete engine replacement.
Jeannie
Lady Fitzgerald
Mr.Mark wrote: MrWizard wrote: the damage to the engine was considerable but is Not catastrophic
Turbo OK
head OK
MM.
More likely, Affinity wasn't qualified to do internal work on Cats.
JohnnyT
Goshen New York
George, sounds worse than hoped for, but much better than it could have been. I am glad you have a definitive resolution in front of you and you can plan the resumption of your trip...
Johnny
2004 40DS02 Travel Supreme ISL 400
Jeep Grand Cherokee
M&G Brake & Break Away
Blue Ox Aventa LX Tow bar
Jim@HiTek
Gresham, OR, USA
I was there at the shop today and got a look at the pistons. Three of them were kind of crumbly on the top surfaces...with holes in them. And the other three look ready to go. Holes in the pistons equals no compression. Like they'd been run hot so many times that the high temp explosions that occur in the cylinders finally broke through. Saw the head too, it looked pretty good, so did the valves.
Jim@HiTek
Have shop, will travel!
Visit my travel & RV repair blog site. Subscribe for emailed updates.
Fleetwood Bounder, '94
Cummins Diesel, 190HP, 36.5' with 50HP LP boost.
Black Rock Lava Park, Nevada
lfeather
Titusville, FL
Has it been determined what caused the overheating? Could it have been bad fuel? After all this work and cost, I'm wondering if you should drain the tank and put some known good diesel in there? Just a thought...
Larry, Debbie, Tiki and Tomi
USAF Retired
2003 36' Country Coach Allure #30856
2008 Tacoma Towed
SMI Air Force One toad brake
JcoFS3500
East Central OK
Catching up on this saga late but if the problem is burned pistons, I'd sure want to get the injectors checked unless the mechanic can give me a very good explanation as to why they burned. Overfuelling (injector problems) can burn holes in the pistons and checking them now is sure cheaper than more new pistons later.
Sorry to hear about your misfortune.
'93 Jayco FS3500 TT behind a '92 Dodge D250 powered by 5.9L Cummins
'94 Vogue Prima Vista powered by 8.3L Cummins w/ 6spd Allison
CA Traveler
The Western States
Wiz,
I know that you are in good hands but: I would replace the injectors (good rebuilds are OK) and I would ask if USLD fuel could be a factor with your engine (and if so what else needs to be considered).
I would also want to know about the overheating. Was it caused as a result of the piston problem and pushing the engine to the next exit. Not trying to be critical at all but just want you to drive away with great confidence in the future.
