RV.Net Open Roads Forum: Dinghy Towing: Ready Brute Elite with integrated brake--brake cable
Search only in Dinghy Towing
Open Roads Forum  >  Dinghy Towing  >  All
 > Ready Brute Elite with integrated brake--brake cable
RVerDiane
Madison, Wisconsin
Posted: 05/19/12 03:03pm Link  |  Quote  |  Print  |  Notify Moderator
I have the Ready Brute Elite with integrated brake and I recently noticed that the plastic coating over the wire on the brake cable was worn away exposing a portion of cable. It appears to be rubbing as it goes through the oval hole before you hook to the brake. I don't know how to explain this very well.
Has anyone else had a problem like this with the brake cable and what did you do?
Thank you in advance.
Diane
Madison, WI
'94 Horizon 21 1/2'
towing '04 Honda CRV
Polishnurse
Schodack, NY
Posted: 05/19/12 03:21pm Link  |  Quote  |  Print  |  Notify Moderator
I don't know, my unit is just plane old wire, twisted. I replacemine about a year ago when it broke where it went thru the fire wall of toad. cost about $3.00 for the new one. Bill
RVerDiane
Madison, Wisconsin
Posted: 05/19/12 03:40pm Link  |  Quote  |  Print  |  Notify Moderator
Polishnurse: what is the fire wall?
gemsworld
Sunny Southern California
Posted: 05/19/12 09:25pm Link  |  Quote  |  Print  |  Notify Moderator
It's the barrier (wall) that separates the inside of the car from the engine compartment.
BozemanTrail
Montana
Posted: 05/20/12 03:49pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, I have had problems with the cable chaffing a lot against the "oval hole" on the ready brute itself. The first thing that helped has to take a dremal tool and take any of the sharp edges off of the 1/4" steel that makes up the area around the hole. In my case, I still wasn't super happy with the results, so I attached a Teflon block with a hole in it. Other folks have come up with other ideas to keep the cable from chaffing...
Dutch_12078
Great Sacandaga Lake, NY
Posted: 05/20/12 08:19pm Link  |  Quote  |  Print  |  Notify Moderator
Ok, you've both got me puzzled. Exactly where is this "oval hole" located?
Dutch
1995 Coachmen Catalina 322QBXL
F53 chassis, 460 V8, TST TPMS
Quadra Bigfoot EZE Levelers
wny_pat
Western NYS
Posted: 05/21/12 12:18pm Link  |  Quote  |  Print  |  Notify Moderator
I'm puzzled too!
RVerDiane
Madison, Wisconsin
Posted: 05/21/12 06:43pm Link  |  Quote  |  Print  |  Notify Moderator
Since I am on the road and have only a few power tools with me, what would be the simplest way to protect the cable? Where did you put the Teflon block with the hole in it?
Thanks.
wny_pat
Western NYS
Posted: 05/21/12 10:04pm Link  |  Quote  |  Print  |  Notify Moderator
The cable is enclosed in a protected braided wire sleeve and should not be rubbing on anything. What exactly is rubbing and what is it rubbing on? The only place it could be rubbing is where the wire exits the sleeve at. That hooks to the exposed unprotected cable. Is that cable the one that is rubbing on something. Are you talking about the "Stow Strap" (item 13) in the pics on pages 8, 10, and 11 of the installation instructions? If you are having a problem there, I suggest you call them with your problem at (800) 933-3372. The Ready Brake support is excellent and I am sure that they will be more than willing to help you out.
* This post was edited 05/21/12 10:19pm by wny_pat *
erstanfo
Northwest, Olympia WA
Posted: 05/22/12 10:25am Link  |  Quote  |  Print  |  Notify Moderator
RVerDiane, I have the same issue. since you are on the road, just line the oval hole with duck tape, overlapping the edges of the bracket.
Others, the oval hole is through the bracket that is used to hook the tow bar up when in the storage mode. The cable goes through it from the car to the bell crank arm.
Ed, Sharon & Doolin the standard poodle
2012 Winnebago Journey 36M
