RV.Net Open Roads Forum: Dinghy Towing: Ready Brute Elite with integrated brake--brake cable
Search only in Dinghy Towing
 > Ready Brute Elite with integrated brake--brake cable
Dutch_12078
Great Sacandaga Lake, NY
Posted: 05/22/12 03:50pm Link  |  Print  |  Notify Moderator
erstanfo wrote:
RVerDiane, I have the same issue. since you are on the road, just line the oval hole with duck tape, overlapping the edges of the bracket.
Others, the oval hole is through the bracket that is used to hook the tow bar up when in the storage mode. The cable goes through it from the car to the bell crank arm.
If your cable is chafing there, then something is likely misaligned. My cable makes no contact there, either at rest or with the brakes applied. Is your connection point at the toad centered and in line with the pivot points? Does the cable chafe at the top, bottom, or one side of the hole.
Dutch
1995 Coachmen Catalina 322QBXL
F53 chassis, 460 V8, TST TPMS
Quadra Bigfoot EZE Levelers
RVerDiane
Madison, Wisconsin
Posted: 05/22/12 08:53pm Link  |  Print  |  Notify Moderator
I believe that it chafes at the bottom but I'll have to check again.
Diane
Madison, WI
'94 Horizon 21 1/2'
towing '04 Honda CRV
RVerDiane
Madison, Wisconsin
Posted: 05/25/12 08:49pm Link  |  Print  |  Notify Moderator
I checked today and the reason it chafes is there's an angle from the hitch down to the car. It rubs on the bottom.
And yes it is the 'stow strap' that I am talking about. I'm where I don't have cell service right now but I will call them when I can. Thanks for the tip.
lb311
Bartlett, IL
Posted: 05/27/12 09:38am Link  |  Print  |  Notify Moderator
My brake cable recently wore off it's plastic shielding there as well (after about a year of towing). Since I'm not seeing any evidence of rust on the cable, I'm just considering it a minor cosmetic issue at this point.
I do think I'll try the tip about lining the oval hole with duct tape-- for those wanting to see a picture, here's a blog post I did last year on the full setup. Look at the "fully-extended arms" pic near the end of the post. The black J-shaped piece that the cable is going thru is what we're talking about).
Overall, after a year with my ReadyBrute Elite, I'm satisfied with it's performance and price value, but wish it'd been a bit more durable cosmetically. Besides the issue above, a few small surface rust spots have appeared on the towbar edges (where the silver paint has flaked off), and the red emergency brake cable lost it's "red" color within a matter of months due to inadequate UV protection. Minor quibbles, but hope NSA can fine-tune their finishing quality to eliminate them in the future.
2008 Winnebago View 24H
2003 Chevy Tracker ZR2 4WD
ReadyBrute Elite towbar with BlueOx baseplate
http://winnieviews.blogspot.com
BozemanTrail
Montana
Posted: 05/27/12 10:20am Link  |  Print  |  Notify Moderator
RVerDiane,
If it is the verticle alignment, make sure you have the hitch attachment to the rv and the attachment to the car within 2 inches (if I recall correctly from the instructions). You can use a drop receiver hitch to get things aligned better.
See the "0"- 10" Drop Trailer Hitch Receivers" section in accessories...
RVerDiane
Madison, Wisconsin
Posted: 05/27/12 02:33pm Link  |  Print  |  Notify Moderator
Thanks for your input. Since I am on the road and will be through July at least, I need some temporary fixes for now. My hitch actually raises instead of drops and I believe that was due to the blue ox baseplate position on my Honda CRV.
How would I get this addressed on the road? I don't have the knowledge to do much but monitor the situation and put duct tape on the 'oval'.
lb311: I wish I had seen your step by step guide when I first got my equipment. So informative.
Thanks.
Dutch_12078
Posted: 05/27/12 09:22pm Link  |  Print  |  Notify Moderator
Most RV dealers will have drop adapters available in different sizes. The installation is simple, and only requires readjusting the length of the brake "dog leash" to accommodate the extra length.
