cvbdsl
Winchester, ON
I'm wondering if Durabond tape totally replaces caulking? I'm wondering if it would be worthwhile to replace the long strips of caulking on each side of the roof with Durabond tape instead?
Any comments?
Thanks
Chris
2003 Dutch Star 4005
1999 Dutch Star DP 3865
2001 Honda CRV - Ready Brute Elite Tow Bar/Blue Ox Base plate
Retired Canadian Army WO (1971-2000)
fordsooperdooty
EternaBond. You can scrape off some of the old caulking and put EternaBond in it's place. Or leave the existing caulk in place, clean it good and cover it with EternaBond.
harold1946
Surprise Arizona
Durabond, Eternabond, and Dicor sealing tapes are all made for sealing "rubber roofs". I do not believe there is ten cents worth of difference in any of them, just personal preferrence.
Harold and Linda
2009 CT Coachworks siena 35V
W-22 Workhorse 8.1L
Explorer toad
bluwtr49
Green Valley, AZ
I've used the Eternabond and it works great. However you don't want to use it where it visible. Not as cosmetic as well applied color matched chaulking.
Dick
2000 40" DP Beaver Patriot Thunder Cat C-12 425 HP, 1550 Tq
1997 Jeep GC Limited ---toad
2008 Toyota Tundra Crew Max Limited TRD (Retired)
2009 Cougar 268 RLS ~8700 lbs road wt (Retrired)
2006 Jeep Liberty Turbo Diesel.....TV in Training
mike4947
N. Syracuse, NY
JMHO but this is a case of you get what you pay for. RV builders that are starting to use tape for sealing have been going to Durabond and the Dicor brand. WHY? They cost less. We have found that while Eternabond costs more it's failure rate if applied correctly is zero.
We have several folks in the extended camping family that have had failures with the other two used as OEM.
We have two coaches going on 15 years with Eternabonded seams with no leaks and no maintenance.
blog.rv.net Your daily guide to the Open Road
Subscribe to the daily digest
They say you learn by your mistakes, in that case I must be a genius.
robsouth
Near Atlanta, GA
"Caulking" is what you do when you apply "Caulk". Just an observation.
"Sometimes I just sit and think. Sometimes I just sit." "Great minds like a think."
harold1946
Surprise Arizona
mike4947 wrote: JMHO but this is a case of you get what you pay for. RV builders that are starting to use tape for sealing have been going to Durabond and the Dicor brand. WHY? They cost less. We have found that while Eternabond costs more it's failure rate if applied correctly is zero.
You tweeked my curiosity. Which rv manufacturers are using Tape as opposed to caulking?
bsinmich
Holland, MI
Eternabond does not look bad when properly applied. I used it around all of the roof seams where they met the walls on my '96 Pace Arrow and it was very visible from the ground. It was a nice white 4" strip all around the MH and looked good. I also never had a leak.
2003 Newmar Mountain Aire, Workhorse W22, 2008 Saturn Vue, Falcon 5250, & US Gear Unified Tow Brake
Lady Fitzgerald
Tempe, AZ, USA, Earth
harold1946 wrote: mike4947 wrote: JMHO but this is a case of you get what you pay for. RV builders that are starting to use tape for sealing have been going to Durabond and the Dicor brand. WHY? They cost less. We have found that while Eternabond costs more it's failure rate if applied correctly is zero.
Jayco uses it on slide roofs. Since they have been having problems with the tape failing, I suspect either they are using a brand inferior to Eternabond or are skimping on surface prep (or both).
Jeannie
cvbdsl
Winchester, ON
Thanks for replies/comments. So basically if the surface is prepared properly and you use a good quality tape it works as well as, or better than caulking?
Thanks
Chris
