RV.Net Open Roads Forum: Truck Campers: yellow plastic vent -- paint it?
 > yellow plastic vent -- paint it?
Francesca Knowles
Port Hadlock, Washington
Posted: 05/19/12 06:40pm Link  |  Print  |  Notify Moderator
When my granddaughter outgrew her pink "Barbie Car", I turned it into a "Ranger Jeep" for my grandson using that special plastic paint- worked real well (except on the tires!), but it's way too expensive .
Next project I discovered that there're actually specific primers available for plastics. If you prime with one of those, you'll get good adhesion of any spray paint, even the cheapest.
" Not every mind that wanders is lost. " With apologies to J.R.R. Tolkien
Dragonfly
Ohio
Posted: 05/19/12 07:29pm Link  |  Print  |  Notify Moderator
_____________________
On my former motor home I painted fiberglass bumpers and body panels. The only way it would work though is by using an "etching primer" first. With that base you could use any paint on top of it. I don't know anything about such a primer for plastic but, if it works as well as it does for fiberglass, it makes a huge difference on important, highly visible components.
Also, I regularly paint plastic Purple Martin Nesting Gourds. The plastic formulated paints last much longer than regular paint but you have to use it the first time. If you start with regular paint, the base will be regular paint for a long time no matter what you put on top of it.
DRAGONFLY - F-150, 4WD, extended cab, long bed, Ecoboost engine, max payload & tow pkg, 17", 7 lug wheels, 10 ply "E" tires, upgraded radiator, shocks & springs, transmission cooler, stabilizer bars, 8200 lbs GVWR, payload 2,280 lbs, 21/16 mpg unloaded.
bigfootford
Fair Oaks, California
Posted: 05/19/12 07:36pm Link  |  Print  |  Notify Moderator
The color is called Colonial White. That's the way it comes.
There are 2 colors, Colonial White and Royal White...
I painted mine...Just old Rustoleum. I buffed with steel wool first.
Check this link for color avail:
http://www.pplmotorhomes.com/parts/rv-stoves/range-hood-vents.htm
And this one:
http://www.pplmotorhomes.com/parts/rv-refrigerators/refrigerator-roof-vent.htm
Jim
2000 2500 9.6 Bigfoot,94 F250, Vision 19.5, Mich 245/70XDS2's, Bilstein shocks, air bags/pump, EU2000, PD 9260,Lifeline 100ah, 200W. solar, Morningstar Sunsaver 15A/ display panel, Trimetric, Delorme/laptop, Holux gps rec,led lights, Wave-3 heat.
bigfootford
Posted: 05/19/12 07:39pm Link  |  Print  |  Notify Moderator
I will add this to the Colonial White....
Bigfoot made the early campers this Colonial White....Everyone said the Gel coat was faded....Not so!
So did some of the small Fiberglass trailers like the Skamp etc....
Jim
JeffPritchard
San Diego California
Posted: 05/19/12 08:08pm Link  |  Print  |  Notify Moderator
Thanks everyone! This topic was much more popular (and controversial) than I expected!
Jeff Pritchard in San Diego
2008 Lance 1191 - 2005 Ford F-350 4X4 Diesel (paid for)
Wilderness Photographer - Click here to see my wilderness images
Kemahsabe
Kemah, TX
Posted: 05/20/12 08:06am Link  |  Print  |  Notify Moderator
I used Krylon Fusion to paint all the yellowed plastic on my TT (except the refrigerator vent - why wasn't it yellow?) 3 or 4 years ago. It still looks great!
Photog101
Garden City, Michigan
Posted: 05/20/12 10:20am Link  |  Print  |  Notify Moderator
I took a little different approach on the vent. I had painted the vent prior to this year on several RVs. It looked OK with the Rustoleum, but just did not look right. So this year the DW asked how much trouble it would be to replace it. I stopped by Camping World and they did not have any in stock. (Lately, it seems like CW would be a nice place to open an RV parts store ... but back to topic) I also stopped by another Camper store and they had several on the shelf for 12.98. I picked up some new screws and a roll of putty tape.
I got home, and set up my ladder, removed the old vent in about 5 minutes (it takes a little work to pry the old one off). Then I took some Acetone and with just a dampened cloth I cleaned the area. Then I used an alcohol soaked rag and cleaned the area even more. I filled the holes with some wood putty and toothpicks, just as a precaution. While I let that dry, the DW had dinner ready and we had a good meal. Upon returning to the project at hand, I laid the new unit up and found that it needed 1/2" trimmed off the inside, so as to fit flush. Trimmed that with a coping saw and it fit perfectly. Then I laid up the putty tape, set the new vent in place and installed the new screws. Trimmed off the excess putty tape and called the DW to take a look.
She was so happy with the new look that she went back in and brought me a snifter of Courviousier XO. Nothing but the best for a good job, that took less than an hour actual working time.
As a side note: I also have a couple of neighbors that have various RVs and will be changing theirs out this year.
Combat Vietnam Veteran Support our troops for serving our great country.
1997 Veri Lite RL1200 on a '02, K3500, CC, DRW, 8.1L, Allison, 4.1 gears, Bridgestone 225/70R19.5 tires.
Sparky69
Brighton, Colorado
Posted: 05/20/12 11:21am Link  |  Print  |  Notify Moderator
Just go get some Purple Power cleaner and mix it 50/50 with water, spary it on the vent, and watch the yellow drip off of it. Rinse it off with water and you should be good until next year.
1998 Freightliner Century C120, Cat C12, 10 speed, 72" Condo sleeper
2006 Forest River All American Sport 385 CKTS
2008 Harley Davidson Road Glide
BudWizer
Pueblo, Colorado
Posted: 05/20/12 11:34am Link  |  Print  |  Notify Moderator
I don't know if my vent is yellow or not. You guys worry way too much about the small stuff!
1995 Winnebago Vectra
2003 Suzuki Grand Vitara toad
AnEv942
CA
Posted: 05/20/12 01:03pm Link  |  Print  |  Notify Moderator
Good point on trimming the snout (long to fit different wall thickness)
Though I trimmed ours I noted the snout is removable (how they install the swing door). You could just swap old on. After removing 2 small screws tilt top out a bit to free from tabs, then pull up or push up from bottom corners slightly to disengage snout from the full length slotted bottom groove.
01 Ford 250 4x4 DRW Diesel, 01 Elkhorn 9U
Our camper projects page
