FB Grateful Dad
Southwest
I planned my first post to be different, new owner, pictures, etc. but I found a problem that needs addressing.
We brought our 2003 Discovery 39S home from PPL. Everything worked in the walk-through (maybe I will delve into old TV systems later). Yesterday during a simulated camp setup at home, the bedroom slide would not extend. Unit was running, levelers down and level, both living room slides were out. Breaker and fuse panel were OK. Before climbing under today, I thought to ask for any suggestions from the wealth of experience I have been observing here.
Thanks, Fred
2003 Discovery 39S
Ms. Froggy - 07 Honda CRV
Fred and Deb
docj
Fulltime--Home is where we park it
You said: "Unit was running, levelers down and level, both living room slides were out." Were you extending the slides while the engine was on? If so it's amazing that any of them worked since they usually are wired so they won't work unless the ignition is off.
Sandie & Joel
2000 40' Beaver Patriot Thunder Princeton--425 HP/1550 ft-lbs CAT C-12
2009 Chevy Malibu LTZ with ReadyBrute tow bar/braking system
Official WiFiRanger Ambassador WFRAMB303
Follow our adventures on Facebook at Weiss Travels
chewbear
Mobile in the USofA;currently Ozark, Alabama
On my 2002 there are 2 power boards under bed, behind AC panel. Fuse blew. can also try swapping connectors should show if fuse or board is blown. Also make sure the spring loaded door beside sliding mirrors closet doors hasn't sprung open. This happened to me and would not let slide go out.
P.S. I usually run slides with Generator running, this gives a tad more voltage to the motor.
2002 Fleetwood Discovery
330 cat. '09 Escape toad.
Kathy & Joe wish you well.
My mind works like lightning,
one brilliant flash and it's
gone. (Maxine)
FB Grateful Dad
Southwest
Thanks docj and chewbear. My manual says ignition on for slide operation. I will try it with the genny in a minute, after I check all the closet doors. I don't recall a spring loaded door there, but that's probably a me problem.
Coalminer UG
Nakusp BC
My slides work with engine running. Thats the way I always extend slides.The emergency brake has to be on before extending slides, same with jacks.
Ches
Served In Canadian Army 1PPCLI
Retired Underground Coal Miner (Gen Foreman)
Black Hills Gypsies
Palm Springs CA
I have to have the key out of ignition before my slides will go out.
This may not be the case for you but it might be.
FB Grateful Dad
Southwest
Well, nothing new. Not a sound from the switch or the slide motor. Tilted the bed up and looked at the slide motor. All wires appear ok and connected. No working room tolerances for trying the "manual slide operation". Barely enough room to hit it with a hammer to vent!
Sign on the switch also states motor must be running.
Thanks everyone
Tsalla Apopka
Crystal River, FL
Are all the slides the same technology? I've heard of some coaches that had both hyraulic and electric slides.
My Holiday Rambler is of the variety that requires the motor to be OFF for the slides to move at all. Both of my slides are electric and I wonder if motor on for hydraulic and motor off for electric is the way of the world???
Denny & Karen
Florida's Beautiful "Nature Coast"
Brit,TDI,BH & Claire,TDI (Belgian Sheepdogs)
Merlot - Sheltie rescue
Glady(Morgan Mare - retired),Toes & Beemer(Barn Cats-retired)
WA4OMG (Old Mangy Goat)
lanerd
Newport, OR
Even if electric... can also be either rack and pinion or cable. Our bedroom slide is cable and can become stretched over time and usage. Usually requires an small adjustment to keep them taught.
Ron
Ron & Sandie
'08 Safari Simba SBD35 CAT C7
Toad: 2011 GMC Terrain SLT2
Tow Bar: Sterling AT
Toad Brakes: Unified U.S. Gear
TPMS: Pressure Pro
Member of: GS, FMCA, Safari Intl, CAT
RETIRED!! How sweet it is....
FB Grateful Dad
Southwest
Good points. I would love it if I could teach them to be taut (sorry Ron), but they are all Power Gear electric with a drive shaft and rollers. Still looking around.
