Biggredd
Denver
I have a hallmark vail pop up camper. Its pretty light weight. I have good tie downs for the front but don't have rear tie downs. But the guy I bought it from did give me brackets that bolt to the rear bumpers. Just not sure if I should do that or not. I'll be taking it on some fire roads and potentially a little rougher. Don't want to ruin my bumper if it can't handle it. Its an 08 f250.
Eycom
32043
I have a F-350 dually with a 4k camper. I use the Happijac tie down system that includes the rear attachments to the rear bumper. 200k miles with the camper and the rear attachments and the bumper are still there.
RVn Full-time
tktplz
Lake Bistineau, Louisiana
For less than $250.00 you can have a frame mounted no drill tie-down with Torklift rear tie-downs. Tweetys.com has them free shipping right now. If you mess up your bumper it will cost allot more than that.
"Confidence is the feeling you have before
you fully understand the situation"
1999 Toyota Tacoma Pre-Runner
TorkLift Tie Downs
2010 Travel Lite 690FD
2007 Honda ARX1200T3D
2008 Yamaha Zuma 50 Scooter
2010 "Blue" Bulldog, "Luna"
Camped 10 Days 2012
big whitey
raleigh,nc
tktplz wrote: For less than $250.00 you can have a frame mounted no drill tie-down with Torklift rear tie-downs. Tweetys.com has them free shipping right now. If you mess up your bumper it will cost allot more than that.
in a word NO!!
kcabpilot
CA
Yes you can use them but the bumpers on the later model Fords need a diagonal support. You can buy them but a couple of lengths of one inch angle iron are all that are necessary.
You can spend $250 for frame mounted Torklifts but your tie down will still not be any stronger than the 3/8 inch eyebolt screwed into the bottom of the camper.
1994 Lance 990 on 1997 F350 PSD Dually "Rhino Haunches"
narcodog
Georgia
Get the TorkLifts. There have been numerous posts about Ford bumpers bending when using mounting points on them.
Bigfootchevy
Bancroft, Ontario, Canada
X2, That's exactly what I was thinking as I read this post.
Paul
youngm357
North Idaho
I have been using bumper buttons for rear tiedowns for years and not one single problem.
jimh425
Western WA
I'm not sure why you would use front mounted frame mounts and bumper mounted rear mounts. I think you should go one way or the other, so in this case, add the rear frame mounts.
Obviously, both types of mounts work for at least a few people.
'06 F350 Lariat Supercab SRW, 6.0 PSD 4x4 Long Bed, Intake Elbow, Walker Big Truck Muffler. '06 Host Rainer 950 Double Slide, Fastguns. Firestone Air Bags, Rancho 9000s, Vision 19.5s with Hankook DH-01 245s, Energy Suspension bump stops.
Bigfoot85
Washington
Our experience with the bumper tiedowns was good ... that is, everything held together. BUT, the rear bumper did twist a few degrees, and it was a noticeable annoyance. This was on Ford 150. We moved to torklifts on the Chevy 2500, and are happier with them. So, in summary, if you have the bucks go for the frame mounted Torklifts. If not, the bumper tie downs will work until you can afford them.
BlazingWest ... in an office with a view
Bigfoot 9.5
2004 Chevy 2500HD 6.0, 4.10 manual
