RV.Net Open Roads Forum: Tech Issues: generators
 > generators
kennethwooster
Perryton Tx USA
Posted: 05/20/12 10:10pm Link  |  Quote  |  Print  |  Notify Moderator
Our Cameo is wired for generator. Onan is the switch that was installed. They are really expensive. Just wondered if anybody else may have found a generator that would fit in place of Onan, and still hook to prewired stuff. I've used Kipor, but would prefer something else. Thanks.
kenneth wooster- retired farmer. Biblical History Teacher in public HS, and substitute teacher.
wife Diana-adult probation officer, now retired.
31KSLS Full Body paint Cameo
Ford F250 2011 model, 4X4, King Ranch.
18K SuperGlide Hitch
pulsar
Lewisville, NC
Posted: 05/21/12 03:41am Link  |  Quote  |  Print  |  Notify Moderator
Moved from Technology Corner to Tech Issues.
eHoefler
ozark mountains
Posted: 05/21/12 06:01am Link  |  Quote  |  Print  |  Notify Moderator
Onan, Kohler, Generac, or any other generator designed to run in a compartment. You can not use just any generator, they have to be designed to run in a confined space. They have special ducting, cooling, exhaust and fuel systems designed for the purpose. Look on EBay and Craig's list for used ones, you can pick one up pretty reasonable if you look .
* This post was edited 05/21/12 06:21am by eHoefler *
2010 Ram 3500, Crew Cab, Long bed, 4 x 4,Dually, Lights & Siren!
2006 40' Landmark Mt. Rushmore
kennethwooster
Perryton Tx USA
Posted: 05/21/12 09:39am Link  |  Quote  |  Print  |  Notify Moderator
Thanks had not about trying ebay for a used one. I won't use one much so used will work great.
KD4UPL
Swoope, VA
Posted: 05/21/12 07:28pm Link  |  Quote  |  Print  |  Notify Moderator
Onan may be expensive but they are good generators. I would stay away from Generac, the bottom of the generator barrel.
 > generators
