RV.Net Open Roads Forum: Fifth-Wheels: Removing unknown sealant from EPDM roof
 > Removing unknown sealant from EPDM roof
I-Can-Am-Can-You
Columbus, OH
Posted: 05/21/12 12:19pm Link  |  Quote  |  Print  |  Notify Moderator
All,
The DPO of my fiver applied some sort of unknown sealer to the longitudinal seams (along the gutters)of my fiver. It looks almost like a latex paint and was clearly brushed on. It would appear to be preventative since there are no signs of leaks. Additional sealing is good except...
It's peeling. Badly. This stuff does not adhere to EPDM well. It could be DPO didn't prep the surface properly, or it's not intended for EPDM roofs. In either case, it looks like crap. What's the best way to get this stuff off? I don't even know what it is. I can hardly imagine I will get more that 50% removed by peeling away at the loose parts. Is there something I can put over the radius of the roof edge to cover it up or is it better to just let it flake away on its own? Let me be clear by saying this stuff is NOT part of the roof membrane. It's clearly something added, perhaps unnecessarily.
Do the longitudinal seams need to be resealed? There's no Dicor along the gutters... I thought the seal was butyl under the gutters?
What do you suggest? I'm going up on the roof this week to apply Eternabond to the vents, front and rear cap. I'd hate to apply 60' of Eternabond to the longitudinal seams if it's not needed. Stuff ain't cheap, and I may want to replace the roof membrane someday so the less to remove later the better.
Thanks for your thoughtful advice.
_______________________________________
2009 Can-Am Renegade 800R X tugged behind a
2005 Crossroads Cruiser CF28RL tugged behind a
2004 Dodge Ram 2500 5.9 Cummins Turbo Diesel
mobilefleet
on the road
Posted: 05/21/12 12:37pm Link  |  Quote  |  Print  |  Notify Moderator
it's probably silicone or latex caulk which isn't compatible with EPDM roofs. Alot of work to remove without tearing up the EPDM rubber, I'd just eternabond the bad areas, or buy the thick eternabond (4") and cut it in half. If you ever need to replace your roof you wouldn't have to remove it anyway, it will just come off with the roof membrane.
Biggziff
Upstate, NY
Posted: 05/21/12 12:49pm Link  |  Quote  |  Print  |  Notify Moderator
Could it be this stuff?
http://www.pplmotorhomes.com/parts/rv-roofs/white-elastomeric-roof-coat.htm
Me and my 3 girls
2013 Cougar 293SAB
2011 F350 CC SWB 6.7
ScottG
Bothell Wa.
Posted: 05/21/12 01:19pm Link  |  Quote  |  Print  |  Notify Moderator
I know exactly what stuff your talking about. Someone put the same sloppy brushed on garbage on an aluminum roofed TT I had. If you leave it alone, it will eventually all fall off. Fortunately with the aluminum roof I was able to use a 3M scotchpad in an angle grinder and remove it easily.
I don't think you need to reseal along there unless there's an obvious reason. I never have.
Scott, Grace and Wesly
H0NDA eu2000i
fla-gypsy
North Florida
Posted: 05/21/12 02:31pm Link  |  Quote  |  Print  |  Notify Moderator
I would keep picking at it over time until it is all off then put the proper Dicor sealant on it.
ExRocketScientist
Laurel, MD
Posted: 05/22/12 05:33am Link  |  Quote  |  Print  |  Notify Moderator
I would just go up on a ladder once a month with a toothbrush and lightly brush it until it is all gone. Don't use your own toothbrush unless you buy a new one to replace it.
ERS
Texas Two Steppers
Beaumont, TX
Posted: 05/22/12 07:07am Link  |  Quote  |  Print  |  Notify Moderator
Take a piece and see how it responds to acetone or laquer thinner. These are recommended for cleaning rubber roofs. I used detergent on my roof, but it was just dirty, and recall that these products were also recommended for cleaning for Eternabond application.
2013 Duramax 3500 dually 4x4
2013 Excel Winslow 31RSE
TST tire monitor
Magnum MS 2012 inverter/charger
3-135w solar panels
Tristar controller
Trimetric monitor
4-6v Trojan t105 batteries
B & W companion 3000 hitch
I-Can-Am-Can-You
Columbus, OH
Posted: 05/22/12 07:13am Link  |  Quote  |  Print  |  Notify Moderator
Thanks to all.
I'm going to try brushing off the loose gunk with a medium bristle brush. What doesn't come off will flake eventually I'd imagine. The medium bristle brush is the recommended cleaning method in the roof manufacturer documentation that came with my trailer.
DPO applied this stuff in a 6" swath covering the entire radius of the roof edge so it's going to look crappy for a while. At least DPO performed preventative maintenance. Although not done well, it's clear the unit was not neglected so I suppose that's good.
I do believe it is that white elastomeric roof coat stuff.
MC9
Cheboygan,MI
Posted: 05/22/12 08:10am Link  |  Quote  |  Print  |  Notify Moderator
I had a couple little v tears along the radius of my 5er so I cleaned real good then alcohol scrubbed. Put on a strip of eternabond on the radius, It didn't like wrapping over the edge. Didn't look good either (too white). Ended up taking it off and just putting dabs of Dicor caulk. A coat of the Kool Seal over the caulk feathered it all in and matched the color.
