RV.Net Open Roads Forum: Towing: What do you torque WD hitch shank bolts?
Search only in Towing
Open Roads Forum  >  Towing
 > What do you torque WD hitch shank bolts?
carjocky
Northwest Ohio
Posted: 05/21/12 06:17pm Link  |  Quote  |  Print  |  Notify Moderator
At what torque do you tighten WD hitch shank bolts?
Thanks
Jon
Ohio
2012 Keystone Bullet Premier 29RTPR
2009 Dodge Ram Crew Cab 1500 5.7 Hemi
BarneyS
S.E. Lower Michigan
Posted: 05/21/12 06:22pm Link  |  Quote  |  Print  |  Notify Moderator
Reese says to torque them to 250-300lb-ft.
Barney
Hensley "Arrow" 1400# hitch
2002 Ford F250 Super Duty, 7.3L PSD
Visit our website here
sharker6
fulltime KY, NC, FL, MA, TN
250 ft/lbs if I remember correctly. I know it's a bunch.
2009 30' Fleetwood Wilderness, 2008 F-250 Super Duty FX4 stump puller
owenssailor
Ontario
Posted: 05/21/12 10:02pm Link  |  Quote  |  Print  |  Notify Moderator
Equal-i-zer specifies 430 Ft-lbs torque for the hitch ball.
owenssailor
Ontario
Posted: 05/21/12 10:06pm Link  |  Quote  |  Print  |  Notify Moderator
Also the shank bolts are to be 320 Ft-lbs
Chuck&Gail
In the Colorado Mountains
Posted: 05/21/12 10:36pm Link  |  Quote  |  Print  |  Notify Moderator
Note any good big truck repair place can torque them for you. Place I went didn't even want money, but I gave him some anyway. It takes a BIG torque wrench. Remember all you need to take is the stinger/drawbar. The trailer is unneeded for that.
Chuck
Wonderful Wife
Australian Shepherd
2010 Ford Expedition TV
ExRocketScientist
Laurel, MD
Posted: 05/22/12 06:20am Link  |  Quote  |  Print  |  Notify Moderator
The ball on my Reese was 450 and the bolts on the shank were 300.
ERS
carjocky
Northwest Ohio
Posted: 05/22/12 06:48am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the replys. I am putting Timberns on the truck today and will need to adjust the height of the shank. So I will torque it to 275-300 and call it a day.
Thanks,
BenK
SF BayArea
Posted: 05/22/12 10:41am Link  |  Quote  |  Print  |  Notify Moderator
The various torque settings mentioned is out of context without the thread dia
Mine came with a tag that said 450 ft/lbs, but on a smaller dia thread that would
be an over torque, which would weaken it
-Ben Picture of my rig
wgriswold
Lake Tahoe
Posted: 05/22/12 01:16pm Link  |  Quote  |  Print  |  Notify Moderator
My Equalizer came with grade 8 bolts to attach the hitch head to the shank but regular washers and nuts. While adjusting and readjusting the hitch the washers and nuts failed and I had to hacksaw off the bolt. Then I got new grade 8 bolts, washers and nuts. No trouble since.
1999 K2500 Suburban, 454, 4.10
Arctic Fox 29V
