RV.Net Open Roads Forum: Travel Trailers: Dang it!!!! Lost my awning yesterday!!
 > Dang it!!!! Lost my awning yesterday!!
anaro
Mebane, NC
Posted: 05/23/12 06:52pm Link  |  Quote  |  Print  |  Notify Moderator
profdant139 wrote:
Well, I have learned something -- I am from Southern Calif, where gentle breezes blow. But we are heading into the Canadian Rockies this summer -- thunder country. So, at the risk of displaying my ignorance -- how do you tie down the awning?? I don't want to roll it up every time we go away for the day!
Thanks in advance for your advice. And if this should be a separate thread (so that I don't hijack Bob's story), I will re-post.
PS -- Bob, that was well-played -- my guess is that your blood pressure is well under control!
With this or this
2009 Ford F250 Lariat Crew Cab 6.4L diesel 4WD
2011 Crossroads Zinger ZT26BL
Reese Dual Cam
4 nights camped in 2013!
21 nights camped in 2012!
27 nights camped in 2011!
BobsYourUncle
Surrey, BC Canada
Posted: 05/23/12 08:09pm Link  |  Quote  |  Print  |  Notify Moderator
profdant139 wrote:
Well... -- how do you tie down the awning?? I don't want to roll it up every time we go away for the day!
Don't worry, the question is fine here.
I don't know how to tie the awning down either!
Duramax / Allison
Fire Red
95 Sportsmen 25.5' TT
81 Citation 25' "Tail dragger" "Under construction"
"Workin' man's rig"
Bob's Trucks
Check Out My Rebuild Project
Project Feedback
profdant139
Posted: 05/24/12 12:15pm Link  |  Quote  |  Print  |  Notify Moderator
Aileen, thanks for the links! Basically, it looks like we loop a rope around each end of the awning roll-up bar and then hook it to an anchor that is screwed into the ground -- I can do that! I would probably add a stout bungee cord as part of the rope assembly to take up slack -- but I might double the bungee cord. Otherwise, it would stretch in a high wind.
Our trips -- pix and text
About our trailer
jerem0621
Sequatchie, TN
Posted: 05/24/12 01:34pm Link  |  Quote  |  Print  |  Notify Moderator
I use ratchet straps and long tent stakes.
Thanks!
Jeremiah
TT: 1995 Layton 2910
Tow Vehicle: 1999 F-350, v10, 2wd, Crew Cab, Dually
Hitch: Draw-Tite Trunnion WD Hitch
Sway Control: Valley dual friction sway control
Brake Control: Tekonsha Voyager
"It's Kind of Fun To Do The Impossible"
~Walt Disney~
the_happiestcamper
Mount Pleasant, SC
Posted: 05/24/12 01:53pm Link  |  Quote  |  Print  |  Notify Moderator
I got the ones from Camping World - they have a spring between the cord and the anchor for that.
Jon, Freesi, Lars, Tucker, Holland
2003 Yukon XL 2500 8.1L 4.10 axle
2010 Dutchmen 28G-GS
CG's we've been to
Gene&Ginny
North Kingstown, RI
Posted: 05/24/12 06:11pm Link  |  Quote  |  Print  |  Notify Moderator
SCVJeff wrote:
...HELP YOURSELF:
Thanks.
Gene and DW Ginny
2008 Toyota 4Runner 4.7L V8 w/factory towing option
2002 Sunline Solaris Lite T2363
Reese Dual Cam Straight Line HP Sway Control
Proud member of the Sunline Club
BobsYourUncle
Surrey, BC Canada
Posted: 05/26/12 11:47pm Link  |  Quote  |  Print  |  Notify Moderator
Well, I think I might be able to fix it.........
