RV.Net Open Roads Forum: Travel Trailers: Slide roof sloping towards trailer
 > Slide roof sloping towards trailer
mtofell1
Oregon
Posted: 05/22/12 10:14pm Link  |  Print  |  Notify Moderator
I'm in the process of reworking my TT parking strip and started thinking about the sitting angle of the trailer. I'm sure I know the "best" answer to this question but guess I'm after opinions of the alternate.
How bad is it to have the slide roof slope towards the main body of the trailer? I'd imagine there's a provision for this in the design to keep water from leaking in?
Realistically, I'd rarely (if ever) have my slide out at home and can easily set things up dead level or even sloped a bit in the "good" direction. I'm really just curious is anyone has any experience with slide roofs sloping back toward the trailer? And, if so, any problems?
Old-Biscuit
Across the USA
Posted: 05/22/12 10:35pm Link  |  Print  |  Notify Moderator
Depending on how well the slide seals work I'm thinking you are inviting water intrusion.
My slide out roofs are sloped away from body of 5'vr and I would have to be set up extremely tilted in order for the roof to slant towards rig. So much so that I would feel like I was walking around inside a carney side show.
Why not set it up level (boards under low side tires) and NOT have to worry about water getting past slide seals?
2007 RAM 3500 QC LB SRW 5.9L CTD 48re 4:10 4K in bed 'quiet genny'
Hit the Road Free & Clear April '07
Francesca Knowles
Port Hadlock, Washington
Posted: 05/22/12 10:48pm Link  |  Print  |  Notify Moderator
Good Lord, man- how long have you been an Oregonian???
Don't you know that Oregon Rain will find even the teensiest place to work its way into your rig, even if it has to go UPHILL to do it????
Why give it the added advantage of a downhill ride???
" Not every mind that wanders is lost. " With apologies to J.R.R. Tolkien
mtofell1
Oregon
Posted: 05/22/12 11:39pm Link  |  Print  |  Notify Moderator
Thanks guys... I get the water intrusion thing.... I'm really just curious if trailers are designed for this?
I honestly didn't remember my last trailer's slides being sloped but they probably were. I never specifically looked. The whole concept of one side of the trailer being lower just came to me today while leveling out by pad and it made me ask. I know it's not good and I'd never do it for any extended period. I just want to know if I "could" if I had to.
Francesca Knowles
Posted: 05/23/12 12:10am Link  |  Print  |  Notify Moderator
Trailers are designed to be level.
In my opinion, if you have a fair pitch to begin with you might be O.K. as far as the slide continuing to drain in the right direction when the trailer's at a bit of a tilt.
But I wouldn't think there'd be built-in provisions for water draining against that seam.
Bucky Badger
Madison, WI
Posted: 05/23/12 06:28am Link  |  Print  |  Notify Moderator
Don't invite trouble
Fred & Jodie, dogs, Zoey & Mika
RIP Bella
2010 F150 5.4, 3.55, 4x4, Equli-z-er Hitch
2007 Forest River Salem 27RB LE
and
2009 Nomad 3980
tbrowne
Springfield, OH
Posted: 05/23/12 07:33am Link  |  Print  |  Notify Moderator
A slide awning will help a great deal if you absolutely can't get it level where you park it. The awning will keep water off of the roof unless rain is windblown at a very steep angle. I doubt any slide seals are truly waterproof if water is laying up against them.
Terry Browne
trickyvic3
Raymond NH.
Posted: 05/23/12 07:59am Link  |  Print  |  Notify Moderator
Always try to have the slide at a slight slant. The slide seals help against wind blown rain, but are not totally water proof. The slide topper does most of the work of keeping the water out.
Also it's a good idea to treat the rubber seals every now and then with a good quality rubber treatment to help keep the rubber soft.
Over time the seals can become hard and brittle, thus no longer doing their job.
Vic
Chuck&Gail
In the Colorado Mountains
Posted: 05/23/12 06:29pm Link  |  Print  |  Notify Moderator
Slide on my Keystone slopes AWAY from main TT body when main body is perfectly level.
Chuck
Wonderful Wife
Australian Shepherd
2010 Ford Expedition TV
spike99
North America
Posted: 05/23/12 07:26pm Link  |  Print  |  Notify Moderator
Rule 1 - Trailer's main chassis must be level - because its fridge needs to be level (or near perfect level) to work efficiently.
Rule 2 - Trailer's slide must have minimum slight slope away from trailer's main chassis. If chassis is level and slide roof is sloped towards the trailer, than slide might need adjusting. Ensure its slide is properly adjusted. If slide is properly adjusted, see rule #3. Especially if large slide.
Rule 3 (that some folks don't use - until its too late). If slide's main beam is sagged downward in its centre (from natrual old age weight), then perhps it needs a compressed center post when slide is in (during its winter storage months). If slide's main support roof beam is supported with a compression pole, the beam's center will press upwards (convex shape). Thus, "slowly" removing natrual sag out of the slide horizonal centre beam. If wondering, I use a verticial support beam on my TT's large slide (to remove natural sag during winter storage months) and it works great. re: - Click Here -
Hope these rules help... Especially #3 rule - that's only used by a few folks.
