sunline1
Northeastern Pa
Have a 97 454 cu k2500 4 wheel drive pickup.
Is the aux cooling fan (Radiator), suppose to run when the air conditioning is on ?
Mine is not running.
If so any tips/advise to check it out.
Thanks
Sunline1
NewsW
US
Electric or engine driven?
BenK
SF BayArea
Here are pictures of my GMT400 7.4L Sub while in the shop after nailing a Land
Rover which jumped a stop sign
Is this the aux fan?
Yes, it is supposed to be on whenever the AC is on.
check the fuse first
-Ben Picture of my rig
sunline1
Northeastern Pa
Yes that's the aux cooling fan which is electric, that I was refeering to will check the fuse.
thanks
Sunline1
NewsW
US
Unplug it, apply battery voltage to it and see if it runs.
If yes, start working backwards to the fuse first, then suspects as needed.
502_Jimmy
Richmond VA
sunline1 wrote: Have a 97 454 cu k2500 4 wheel drive pickup.
Thanks
Sunline1
I have two 454 vehicles of that era. '99 K2500 suburban and a '96 K3500 truck. Neither fan comes on just with the A/C. Computer has to sense a certain temperature/heat load for it to come on in my trucks.
Hope this helps.
John
sunline1
Northeastern Pa
Is the fuse an "inline" fuse or is it in the fuse panel inside the truck ?
NewsW
US
Since you had a crash, wiring can be damaged and shorted.
Suspect but do not know -- it is probably a dash fuse.. check the manual.
Turtle n Peeps
California
Did I miss it? Where did the OP say he was in a crash?
outside the fire"
Trail-Mate
Frederick, MD
My 93 K2500 would come on with AC and I think the Van 95 Chevy 1 ton with 454 would also come on with AC.
1997 Ford F250 Extended Cab, 7.3 Diesel, 8 foot bed.
Reese 16K Hitch
(Moved into Shed) Hensley Arrow
Jordan Brake Controller, Hensley TruControl Gold Shelved.
Open Range 5th Wheel, Roamer RF392 BHS
Happy Camping !!
