RV.Net Open Roads Forum: Toy Haulers: Fleedwood Gearbox Ramp Door Frame
Search only in Toy Haulers
 > Fleedwood Gearbox Ramp Door Frame
#1Flyboy
California
Posted: 05/23/12 03:05pm Link  |  Quote  |  Print  |  Notify Moderator
. . .Hey. . .It appears that the ramp door assembly might be vibrating itself away from the back of my Fleetwood Gearbox 295FS 5th wheel. Anyone else seen this? What did you do to repair? Thanks. . .Happy Camping
mobilefleet
on the road
Posted: 05/23/12 04:11pm Link  |  Quote  |  Print  |  Notify Moderator
maybe install some new latches on both sides, from a trailer shop. properly installed latches will have some pressure fit to them and be a little difficult to shut. If they are easy to open and close I'd say you have an issue. Check all bolts and nuts, rivets, or hinge assemblies on the door and tighten as necessary. If they didn't use lock washers from the factory (or locknuts, even better) it would be wise to use those to keep things from backing out due to vibration
DuneJunkie
Reedsport, OR.
Posted: 05/23/12 05:31pm Link  |  Quote  |  Print  |  Notify Moderator
Not sure where are you seeing seperation. Can you post us a picture? I had the upper plastic valence crack and it got replaced. But, I would love to see exactly what & where you are seeing it.
2005 Chevy 2500HD 4x4 CC Duramax/Allison, with 18K SuperGlide Hitch
2008 385 Fleetwood Gearbox
2005 Yamaha YFZ 450
2002 Honda 400ex
skybry
Hughson, CA
Posted: 05/23/12 11:33pm Link  |  Quote  |  Print  |  Notify Moderator
Been there. Replace upper lag bolts with bigger ones that mount door frame to side wall. The the lag screws have a tendency to rip out of the thin wall aluminum tubing when travling on Californa's road system. Took me a year and a half to get this fixed under warranty when Fleetwood was still in business. Now you can fix it yourself in an hour and aviod the BS.
05 Chevy CC Dmax
06 Fleetwood Gearbox 295FS
07 Honda CRF450X
06 Kawazuki KFX400
07 Jetmoto
jeffws
Ladera Ranch CA
Posted: 05/24/12 08:01am Link  |  Quote  |  Print  |  Notify Moderator
Yup pretty common - I just pulled it back into place and replaced all the screws with one size bigger and added twice the screws (one every 6" instead of every 12-18")Its been a couple years and Ive had no problems since...
I have also seen one guy who used carriage bolts from the outside through to the inside with acorn nuts on the inside.
00 FLHR
03 XR 50
05 CRF 70
03 XR 80
05 CRF 230F
06 Yamaha Rhino
06 KTM 525 EXC
05 F-250 CC,4X4,6.0 PSD
06 Gearbox 295FS
05 Carson 7x10
ljbsvt
THE OC Baby
Posted: 05/24/12 06:08pm Link  |  Quote  |  Print  |  Notify Moderator
pretty much the same thing from all of us that have these units.
about 1/2 of the screws were stripped on mine (gotta love cheap labor with air tools)
Like Jeff, I went to a larger screw and put in at least twice as many. Did it a couple of years ago and at least 5,000 miles back, no issues.
2011 F-250 6.7 Lariet CC/SB Loaded
2011 Jeep Wrangler Sport
2007 Gearbox 295FS
Pullrite Superglide
2004 KTM 525 MXC - Mine
2006 Polaris Preditor 500 - Her's
2007 Raptor 700R - Mine
2008 Rhino - ours
Member ASA, CORVA
