RV.Net Open Roads Forum: Fifth-Wheels: Broken spring
 > Broken spring
MC9
Cheboygan,MI
Posted: 05/24/12 04:35pm Link  |  Quote  |  Print  |  Notify Moderator
The 5er is a 2010 Sundance 2900MK. I questioned about putting on all new springs and the spring guy so don't bother they don't really wear out. When he tuned up the arch he said it was still good steel. Still though, he didn't buy chinese steel for his spring work. His stuff was all from Canada.
jjj
Lancaster,Ca.U.S.A.
Posted: 05/24/12 05:33pm Link  |  Quote  |  Print  |  Notify Moderator
I just recently replaced my 4 leaf 3000 lb springs on my 6000 lb. axels to 6 leaf 3300 lb springs for a little added insurance. Mine were already 8 years old and were losing their arc.
2002 F-350 Crew-Cab Dually
V-10-4.30 gears Mag-Hytec diff.cover
w/Amsoil-6.0 trans cooler Curt Q5 20K hitch & bedsaver
2005 Keystone Challenger 34TBH-Fifth Airbourn
Pipewelder
Please don't tell me they welded the spring to fix it... If they did get it replaced ASAP!!! Spring steel is high tensile strength and welding will cause it to become soft and loss its tensile strength.(will no longer spring back as it should). Also if it is not welded correctly, preheated and post heated it can crack or break with out warning!!!
Take care and be safe,
David
MC9
Cheboygan,MI
Posted: 05/24/12 06:04pm Link  |  Quote  |  Print  |  Notify Moderator
No way. Took the spring apart and put in a new #2 leaf and re arched everything put it back together.
Pipewelder
Posted: 05/24/12 06:08pm Link  |  Quote  |  Print  |  Notify Moderator
Thank goodness!!! Glad they did it right!!!
Have fun and Safe travels!!
David
N3YMY
Brunswick, MD
Posted: 05/25/12 05:36pm Link  |  Quote  |  Print  |  Notify Moderator
MC9 wrote:
While tuning up the 5er for a trip I noticed a broken leaf on the doorside front axle spring. To make a long story short I took the spring off and took it to a spring repair place. They fixed it in about 20 min. Charged me 20 bucks. Midway Spring Afton, MI
Don't forget to inspect your spring shackles as well.
Often by the time a spring fails, the shackles also require replacement.
Good time for heavy duty shackles w/wet bolts...
gitane59
Ontario, Can
Posted: 05/25/12 05:53pm Link  |  Quote  |  Print  |  Notify Moderator
I snapped a spring 20 miles from a campground one afternoon last year. Upon closer inspection there were cracks in leaves of 2 other springs.
I paid a premium to have a mobile trailer repair shop come to the campground and replace all four. Would have saved a lot inspecting and replacing pro-actively before trip.
Upgraded from 3000 lb to 3500 lb springs. spring cost was only $45 bucks a piece.
Emergency overnight shipping of each spring cost almost as much as the spring. Ouch!!
Lesson learned, inspect your springs with a bright light occasionally.
* This post was edited 05/26/12 11:20am by gitane59 *
Pictures of Newmar Renovation
C Schomer
Buckeye, Az.
Posted: 05/26/12 10:53am Link  |  Quote  |  Print  |  Notify Moderator
The only time I ever had a broken spring(s) was from overloading my trucks. There has to be a reason why it broke. I wouldn't trust the rest of them if I had any one of them break. I went from 2600 to 3000 lbs packs (Dexters recommendation) on my 5er and it was the best thing I could have done. Hopefully the spring shop is right. I'm sure they know springs better than I do. Craig
 > Broken spring
