RV.Net Open Roads Forum: Tech Issues: Single cup coffee maker amp draw
 > Single cup coffee maker amp draw
Page of 6
Texas Two Steppers
Beaumont, TX
Posted: 05/25/12 07:34am Link  |  Quote  |  Print  |  Notify Moderator
DW bought a single cup coffee maker that draws 150 amps @12v for about a minute and a half. The draw is not constant but pulsates for about 20 second bursts at a time. My system is 440 amp hrs (4-6v Interstates). 1 cup is generally made around 6:00am, 7:00am and 8:00am. Has worked fine for several days when boondocking. This morning my system was down to about 92% from the night before and when I make the early cup the Magnum went off under low battery which I have set at 11.0 volts. Is this too much of a draw for battery health and/or can I lower the LBCO a little more?
2013 Duramax 3500 dually 4x4
2013 Excel Winslow 31RSE
TST tire monitor
Magnum MS 2012 inverter/charger
3-135w solar panels
Tristar controller
Trimetric monitor
4-6v Trojan t105 batteries
B & W companion 3000 hitch
LittleBill
Scranton, PA USA
Posted: 05/25/12 07:37am Link  |  Quote  |  Print  |  Notify Moderator
what wire guage you have between the magnum and the battery's and how long of a run?
Texas Two Steppers
Beaumont, TX
Posted: 05/25/12 07:41am Link  |  Quote  |  Print  |  Notify Moderator
2/0 6-7 ft.
mena661
Posted: 05/25/12 07:54am Link  |  Quote  |  Print  |  Notify Moderator
Texas Two Steppers wrote:
2/0 6-7 ft.
1.3% voltage drop. Should be good. Might be pushing it on the current handling capacity (depends on what the insulation is rated at). I think 4/0 is typically recommended by the manufacturers for 2000W inverters.
Trojan L16 6V's 740 Amp-hours
pianotuna
Regina, SK, Canada
Posted: 05/25/12 08:06am Link  |  Quote  |  Print  |  Notify Moderator
Hi,
Six volt jars don't like the rate of discharge so they exhibit voltage drop. Try monitoring the voltage while running the pot. If the batteries "bounce" back in voltage after the load try 10.5 volts on the inverter.
The real solution is two more batteries.
Regards, Don
Kustom Koach Class C 28'5" 256 watts Unisolar, 875 amp hours in two battery banks 12 volt batteries, 2500 MSW watt inverter.
garym114
Bluff Dale, Texas
Posted: 05/25/12 08:07am Link  |  Quote  |  Print  |  Notify Moderator
You just have to realize what is going on.
When you have a high draw on the batteries, the battery voltage drops under load. How much it drops depends on the original charge level and the amps being drawn. The battery voltage will go back up after the coffee maker is done.
You can either silence the alarm or drop the alarm level and take a look at battery voltage after it sits for a while.
Sit back and enjoy the coffee.
I don't think you need larger cable or more batteries. System respond this way. It's probably the highest amp draw your system sees. I see the same thing with six batteries and a high current draw with 4/0 cable. The voltage goes back up with reduced load.
* This post was edited 05/25/12 08:13am by garym114 *
janstey58
Glenwood, IA
Posted: 05/25/12 08:10am Link  |  Quote  |  Print  |  Notify Moderator
Bad info here, your RV is only wired for 30-50 Amps, outlets are fused for 20 Amps. If this were true (150A), it would blow all breakers.
Jeff and Kim
2009 Bounder 35H (Gas Workhorse chassis)
2012 Ford Escape Limited Toad
garym114
Bluff Dale, Texas
Posted: 05/25/12 08:15am Link  |  Quote  |  Print  |  Notify Moderator
It draws 150 amps at 12 volts, not 110v.
mena661
Posted: 05/25/12 08:23am Link  |  Quote  |  Print  |  Notify Moderator
He said in the first post that it was 150 amps at 12V.
pianotuna wrote:
Hi,
So do 12V's and according to a test here (that you were involved in also), the difference was negligible between the 6's and 12's. Also, there are tons of people here (you might know one....BFL13??), that do this very successfully on 6's.
Texas Two Steppers
Beaumont, TX
Posted: 05/25/12 08:26am Link  |  Quote  |  Print  |  Notify Moderator
The 150 amps@12v is derived from the Trimetric.
Page of 6
