jamstoyz
Chesterfield MI
My rv is parked in my driveway and we are getting a ton of ants under the cushion of the cab over bed. I did have a water leak and the walls got wet. Could they be living in the walls? I tried ant traps and raid. We took the bed out but when we put it back in they reappear.
2001 Gulfstream Yellowstone 29'
1999 Fleetwood Prowler TT 24' (sold)
2004 Fleetwood Gearbox Toyhauler 28' (sold)
The_Painting_Teacher
Cape Cod, MA/St. Augustine, FL
"Home Defense" available at Home Depot and sprayed on every surface that touches the ground .... we've had good luck using that in Fla. However, once they're in, I have no idea other than ant traps. Good luck. Camp on!
Eycom
32043
Terro Liquid... ants, along with their nest, are history. Big boys like Lowes or Home Depo usually carry it. Might find it at your local hardware store.
RVn Full-time
mike4947
N. Syracuse, NY
One question, are the ants the normal less than a 1/2 inch types or larger ones?
Larger ones could very well be carpenter ants and they are drawn to and nest in wet wood. Once the colony is started drying out won't get rid of them.
We usually use one of the baits that the ants take back to the nest. That way you get the queen and without her the colony dies off.
blog.rv.net Your daily guide to the Open Road
Subscribe to the daily digest
They say you learn by your mistakes, in that case I must be a genius.
Twomed
FL winters and then somewhere cool
X2 on Terro....Liquid or the baits, kills them all big or small.
Happy Trails
06 Monaco Dynasty
07 Hummer H3
FMCA 279843
Francesca Knowles
Port Hadlock, Washington
Is it possible they've got a nest in the BED?
" Not every mind that wanders is lost. " With apologies to J.R.R. Tolkien
knuts1
Mound mn
Eycom wrote: Terro Liquid... ants, along with their nest, are history. Big boys like Lowes or Home Depo usually carry it. Might find it at your local hardware store.
this stuff is wonderful and you should be able to find it at Target and Walmart as well.
jamstoyz
Chesterfield MI
The bed doesnt have ants cause we took the cover off and washed it. I tried the Terro stuff but it isnt working. Im lost on this one. I sprayed Raid last night and went out this morning and there was dead ants with a couple live ones. They are the tiny ants and not carpenter. Thanks for all the replies.
jassrnj
Bath, PA
I had ants in my TT and did all of the regular stuff to get rid of them. What I found out much later was that I had water damage inside of the wall. That kept them coming in until the window was resealed and the water damage repaired. If you keep getting the large ants, look for leaks that will keep them coming in .
jamstoyz
Chesterfield MI
jassrnj wrote: I had ants in my TT and did all of the regular stuff to get rid of them. What I found out much later was that I had water damage inside of the wall. That kept them coming in until the window was resealed and the water damage repaired. If you keep getting the large ants, look for leaks that will keep them coming in .
Yeah thats where I think there coming from cause the walls did get wet from the leak I had. Im just hoping I dont have to tear the wall open.
