RV.Net Open Roads Forum: A little put off.... A rant and a suggestion
Search only in Forum Technical Support
Open Roads Forum  >  Forum Technical Support
 > A little put off.... A rant and a suggestion
tandkj
Full timer
Posted: 05/26/12 08:53am Link  |  Quote  |  Print  |  Notify Moderator
Scrape it off and have a good day.
Tis another fine day to serve in and for the glory of the Corps. Every day is a holiday and every meal a feast.
08 Camelot
07 Ranger Toad
One Golden Retriever at the Rainbow Bridge and a new one traveling with us.
pulsar
Lewisville, NC
Posted: 05/26/12 02:22pm Link  |  Quote  |  Print  |  Notify Moderator
AprilWhine wrote:
On a forum where I am a moderator, we use vBulletin software that allows you to set up an automatic message send when a post is deleted. If this software allows a similar action, could be a good idea?
This software doesn't.
Tom
westernrvparkowner
montana
Posted: 05/26/12 03:01pm Link  |  Quote  |  Print  |  Notify Moderator
pulsar wrote:
When I started moderating, I send private messages to each member whose post I deleted or edited. I think most of the moderators started with that philosophy. Unfortunately, most members took the courtesy notification to be an invitation to debate (argue). I've been called every name you can imagine.
Although I will still send private messages to new members explaining why I deleted or edited a post, i've given up on send them to others.
Tom
I always though the moderators were just want-to-be magicians and liked making posts diappear. If the PMs I sometimes get are any indication, you are absolutely right that there is no upside to an explanation. There are a few very seriously disturbed individuals lurking in the forum's shadows. Thanks for the imput and have a great weekend.
full_mosey
Oklahoma
Posted: 05/26/12 03:46pm Link  |  Quote  |  Print  |  Notify Moderator
I suggest you post again if that happens. Include a footnote to the moderator explaining the situation. You should get a PM from the moderator if it is 'lost' again. Right, moderators?
HTH;
John
Francesca Knowles
Port Hadlock, Washington
Posted: 05/26/12 04:01pm Link  |  Quote  |  Print  |  Notify Moderator
HTH;
John
Why?
" Not every mind that wanders is lost. " With apologies to J.R.R. Tolkien
pulsar
Lewisville, NC
Posted: 05/26/12 04:06pm Link  |  Quote  |  Print  |  Notify Moderator
HTH;
John
Myself and Admin are the only ones who, generally, read this forum. I might add, that once you've "called out" a moderator with a post on the forum, you not likely to get a courtesy notification.
Tom
Jerrybo66
AZ
Posted: 05/27/12 05:19pm Link  |  Quote  |  Print  |  Notify Moderator
Francesca Knowles wrote:
HTH;
John
Why?
Really. Why? It's a free forum. The OP seems like a good guy with a reasonable question but why the concern? Why would one zapped post be important? This is a great forum. Some information is valuable, some not worth reading as probably this one. So, some posts fall through the cracks for some reason, others will replace them. Ya' win some, ya' lose some...Just consider, it's free.. IMO..
Support the Country you live in or live in the Country you support
2003 Sierra SP 26'Toy Hauler
1997 F-350, PSD, 4X4, red Crew Cab, long bed.
2007 Arctic Cat Prowler, Arctic Cat 500
