RV.Net Open Roads Forum: Technology Corner: WiFi to old laptop
 > WiFi to old laptop
jauguston
Bellingham, WA
Posted: 05/26/12 09:36am Link  |  Quote  |  Print  |  Notify Moderator
The Alfa that Cactus John linked to is one of the best. I use one with a Jefatech 19db flat panel antenna and the range is amazng.
Jim
2005 Coachman Sportscoach Elite 402 40'
350hp Cat C-7 w/MP-8
7500w Onan quiet diesel generator
6-Kyocera 130w solar panels SB3024i MPPT controller
Pressure Pro TPMS
1987 Suzuki Samurai tintop Toad w/VW 1.6 turbo diesel power
Wherever I happen to park
Posted: 05/26/12 10:06am Link  |  Quote  |  Print  |  Notify Moderator
IF you can find one what I would recommend for you is a Linksys WGA-54G, This is not your normal USB Wi-Fi adapter.. It is a Wi-Fi MODEM, your computer sees it as it would see a wired router. You run CAT-5 Cable to it.
What does this mean?
Maximum length of USB cable is 10-30 feet (Not sure) That is how far from your comptuer you can put a USB device, plus your comptuer is usb 1.
Max length for a LAN cable is 300 feet. Allowing you to put the adapter outside the RV, on the roof, on a ladder, wherever you can put it for the best "View" of the router.
This adapter also has an antenna that sticks up, you can google WI-FI Booster RV and for a few cents, yes CENTS, make a device that slips over the antenna and gives you improved range. (Look for a PDF flie on that google links page)
I use one to feed a router in my "house" then link that to my other devices.
johnvb
Virginia Beach /Virginia/USA
Posted: 05/26/12 12:23pm Link  |  Quote  |  Print  |  Notify Moderator
Appreciate all the help. I notice on the Alfa site there is a disclaimer that USB 1.1 may not provide enough power. But further down on the page a comment is made regarding using a self powered USB hub to boost the signal. I already have one of those, does this sound Kosher?
Also they give two different models, one for 802.11 "b" or "g" service, another for the 802.11 "n". Which of these services do most parks use?
http://www.data-alliance.net/wiki/usb-ba........ibility-2011-for-1000mw-2000mw-adapters/
jauguston
Bellingham, WA
Posted: 05/26/12 12:43pm Link  |  Quote  |  Print  |  Notify Moderator
I use the 2000w one and it seems to get them all. I have three- started with the 500w one then got a 1000 when they came out and then the 2000 when it came out. Each was a quantum leap better than the last.
The Jefatech 19db flat panel is a powerful but directional antenna. You have to rotate it to find the strongest signals.
Jim
strollin
San Martin, CA
Posted: 05/27/12 09:25am Link  |  Quote  |  Print  |  Notify Moderator
If you get an 802.11 "N" capable wifi adapter it will be backwards compatible to "B" and "G". Most wif hotspots I encounter are 802.11 "G".
