RV.Net Open Roads Forum: Forum Technical Support: Problems posting
Search only in Forum Technical Support
Open Roads Forum  >  Forum Technical Support
 > Problems posting
ROYBUCK
Newport NC
Posted: 05/26/12 09:35am Link  |  Print  |  Notify Moderator
I have tried to post on the canada and alaska forum and the Class A forum, with no luck would not post. I did post on the RV Park forum. Does any one know what my problem might be, it goes through the process of loading but it will never finish. Thanks Roy
Roy B Coal Miners Son
USMC Ret
Semper Fi
2002 Endeavor 330 ISC 3 Slides
powderman426
ohio
Posted: 05/26/12 10:05am Link  |  Print  |  Notify Moderator
Try a different portal like woodall.com
Ron & Charlotte
WD8CBT since 1976
28' Prowler & 05 Ram QC LB
I started with nothing and I still have most of it left
I never fail, I just succeed in finding out what doesn't work
Clay L
Sioux Falls, South Dakota
Posted: 05/26/12 11:31am Link  |  Print  |  Notify Moderator
There have been some problems lately. For example posts with percent signs won't go through.
They will go through if you use the Woodall portal as Ron suggests.
Clay (WA5NMR), Lee (Wife), Katie (cat).
Full Timing in a 2004 Winnebago Sightseer 35N, Workhorse chassis, Honda Accord toad
pulsar
Lewisville, NC
Posted: 05/26/12 02:38pm Link  |  Print  |  Notify Moderator
And there are a few other characters that the RV.Net portal will not handle. "Smart" quotes, both single and double, will not work.
Tom
NC Hauler
Asheville NC
Posted: 05/26/12 04:11pm Link  |  Print  |  Notify Moderator
I gave up on rv.net, it's become a joke to try to get to the forums that way, I now use Trailer Life forums and have had no issues getting to the forums from there.
Jim & Kathy
2013 Dodge 3500DRW Longhorn 4X4/CC/LB/Aisin tranny/4:10/Cummins: 385HP/850TQ
06 HR Presidential Suite 37RLQ/ 4 slide/ dual pane windows/Winegard SK3005 Satellite/Splendide XC2100 W/D
Boxers;Buddy& Sheba II
USAF 71-75 Nam Vet
WVU fan
MrWizard
Traveling
Posted: 05/26/12 09:26pm Link  |  Print  |  Notify Moderator
moved from technology corner
Connected thru Verizon with HotSopt WiFi using a Samsung Galaxy Nexus
I BOUGHTthis phone
NavyDood
NW of DFW
Posted: 05/27/12 12:37pm Link  |  Print  |  Notify Moderator
I have also had off and on problems when going through rv.net over the past couple fo weeks. I think I will continue to login through trailer life from now on.
- Retired Navy Chief
- Vanilla 04 2500 QCSB, 4x4, 48RE w/MagHytec DD, Smarty Jr, 4" Exh, Modded Air Box, Isspro Gauges, Quadzilla RPG w/fuel pressure, DynaTrac front, Coolant By-Pass Filter
- 06 Pilgrim 30RE2SLF-5 13,300lbs loaded. B&W Companion
 > Problems posting
