DKean
Mays Landing NJ.
We have been thinking about getting a used class A. Prefer gas but would go diesel if it was a good deal. I saw a 2000 Alpine coach. Is that a western RV product. Aren't they out of business? I saw another coach that said it was a cummins diesel 225 HP. Is that a miss print. I thought the small cimmins for the rv's were 300 hp and up.
2006 F350 CC LB 6.0 diesel dually. 2006 Cedar Creek fifth wheel. Six 6 volt golf cart batteries,3000 watt inverter. Mountain Master generator in truck bed remote start. Automatic satellite dish.Air suspension on truck and trailer.Level up with 6 jacks RC
Gale Hawkins
Murray, KY
All MH options vary a lot based on year of build.
What is your projected MH buying budget and floor plan needs are your to main things to figure out I think.
Wild One
babylon new york
I've been look for a dsl myself and most of the smaller motors were 275 HP if it has a 225 I would stay away myself it would be a dog.
95 Holiday Rambler Endeavor
michelb
Ottawa, ON, Canada
I'd be pretty surprised if any Alpines came with a 225HP engine. That said, a 225HP diesel mh will likely still have more torque (and would likely get much better mileage) than any gasser mh.
Not saying that you need to get a diesel but if power is one of your concerns, diesel will probably always beat gas in the mh market.
daveshan
Durango Colrado
Western RV is out of business, a victim of the collapse of '08. That being said the coaches are one of the best handling and riding ones out there and are well built. The chassis was manufactured in house and is a 4 air bag with a very long wheelbase for the length of the coach. It does use hydraulic discs on all 4 wheels which work very well if maintained. Getting work done on the coach is no problem at all, our local (town of 16,000) diesel mechanic is more than able to work on any of the engine/trans/braking systems and the rest of the RV with the exception of the body shell is off the shelf parts so any RV place can fix the systems.
For 2000 the 36' models the standard engine was a 275hp/815ft lb ISC, I've never seen one as most were ordered with the optional 330/950 ISC, 38' and 40' models got the 330/950 ISC standard.
More information can be found in the irv2 Alpine forum and the Alpine Coach Tech' pages
We absolutely love our 36' side entry (330/950 ISC) my wife has back issues and hasn't been able to travel for years. So far this year we've spent 18 nights traveling with drives up to 8 hours in duration with no problems, it's that smooth.
As with all coaches previous maintenance is the key. And have it inspected by someone before buying.
'99 Alpine 36SDS/8.3 ISC 330 Cummins
Or
'05 Lance 845
'06 Super duty SC/SB 6.0
Upgrades include: StabilLoads, Air Bags & Timbrens,Swaybars
Usually towing an '01 Wrangler, lifted/locked on 35"s or a mildly built '98 Cherokee on 33"s (only one locker)
sdianel
Tampa, FL
We have a Country Coach Allure. Country Coach also went under but a used coach usually isn't covered under warranty anymore anyway. I would buy another Country Coach.
Lonny & Diane
2004 Country Coach Allure 33' "Big Blue"
Towing 2008 Chev Colorado 4x4
Semper Fi
Fishinghat
Western Washington, USA
The 225 HP is probably a Cummins 5.9 "B" engine, the smallest used in motorhomes. It could be a very early version of the Cummins 8.3 "C", but as of 1993 the 8.3 was available in 250 and 300 HP versions, so it would have to be earlier than 1993. Both the "B" and "C" engines were mechanical (not computer controled), very reliable and will outlast the coach and probably you if taken care of.
Holiday Rambler Navigator DP, Hummer, and Honda VT1100C Shadow
dan23
Upstate NY
michelb wrote: I'd be pretty surprised if any Alpines came with a 225HP engine. That said, a 225HP diesel mh will likely still have more torque (and would likely get much better mileage) than any gasser mh.
Well, diesels had better get increased gas mileage since diesel fuel costs significantly more than gasoline. And that doesn't even count the cost of cleaning up the fuel that inevitably gets tracked into your coach from around the pumps.
Valkyriebush
Yuma/Port Townsend
I thik Alpine is a very nice coach. I agree, I'd be surprised if it came with a 225hp engine.
Command Master Chief (AW) USN, (ret)
2003 Fleetwood Excursion 330 Turbo Cat 39D
2000 Jeep GC
2005 Big Ruckus (Rides Behind Jeep)
2003 VTX 1800
