rmatteucci
US
I have purchased a Roadmaster Falcon AT tow bar for my 2011 Itasca Cambria 30C which I will be towing a 2012 Ford Escape. My question is do I have to run the transmission in the tow mode all the time or only when I am in hilly areas. What does the tow selector do to the transmission. I was reading somewhere that it helps in slowing down the RV to help with breaking. Does it hurt the gas mileage or is there any speed restrictions in the tow mode. The Cambria is on a Ford E450 Chassis with a TorqShift 5 speed automatic transmission with a 6.8L V-10 Engine. Any other towing tips would be appreciated.
Towing 2008 Jeep Wrangler Sahara 2D
have bible will travel
St. Joseph, MO. USA
We have a 28b Cambria which has a tow haul feature on the end of the shift lever. We use this gear anytime we tow. This transmission works well on hills going up and down. Shifts down helps the braking. Have fun with your Cambria.
OH48Lt
Whitehouse, OH
The tow/haul feature changes the transmission shift points. It will assist with braking by being more aggressive on downshifting when decreasing speed, and will assist when accelerating by holding the upshifts to a higher RPM. It will not damage your trans to have it in tow/haul at any time. Its a useful feature when you are towing another vehicle or trailer. It shouldn't effect your fuel mileage -may even improve it- but any change either way will be small.
2011 Ford F-150 Lariat Crew Cab 4x4 EcoBoost
2014 Cruiser RV Fun Finder 215WKS
2012 Harley Street Glide -ember red sunglo
Yamaha Grizzly 660 (his)
Polaris Sportsman 500 H.O.(hers)
rjstractor
Auburn, WA
This transmission mode is actually "tow/haul" mode and can be used for any time you are moving a heavy load. A motorhome is always moving a heavy load even when it's empty, so you can use the mode any time conditions dictate, whether towing or not. The amount of weight added to your total weight moved when you tow is relatively little, so you should not notice a huge difference in performance anyway when towing.
1998 Gulfstream Ultra B/H Ford E450 V10
2005 Chevy 2500HD 6.0 w/ Maxidump insert
2006 Ford Escape Hybrid
1998 Saturn SL2 toad
2012 VW Jetta S
rvten
Crossville,TN
I only use the TH when going down hills and exiting the interstate for extra braking.
With TH on.The trans. Will hold a lower gear longer (extend the shift point).
Tom & Bonnie
Crossville, TN.
Aspect 29H 2008 Type C
Ford Flex SEL 2010
There is no B+
luvlabs
Frederick, MD
I would only use Tow/Haul in descending (or climbing) significant grades. It's not needed for routine driving with your toad.
2012 Tiffin Allegro 32CA
2012 Honda Fit
DouglasC
Summerdale, AL
rvten wrote: I only use the TH when going down hills and exiting the interstate for extra braking.
I do the same thing, using TH mostly for making the transmission downshift to a lower gear when decelerating so to aid in braking. Leaving it in TH while accelerating seems to cause the RPMs to go too high before the tranny upshifts IMO. I have 40,000 miles on my E450 with the V-10 so far and have had no problems using this method.
Doug
2006 Jayco Greyhawk Model 27DS
Towing 2012 Ford Fusion Hybrid with Brake Buddy
rmatteucci
US
Thanks for the replies. I guess I will have to try it out on all the time while towing and see what it does and then decide on whether to use it intermittently while going up or down hill. Good point about be able to use it with or without towing I have gone up and down hills in NY and thought a lower gear on the transmission would have been in order the changed shift pattern for towing might be what I could have used. Thanks.
Jack&Kay
Santa Rosa, Ca
Thanks for the useful information on the Tow/Haul switch. I have not really used it on this rig, but since I intend to tow our Honda, I might have to get used to it. The thing I have noticced in the past is that the tranny will downshift when to have your foot on the brake. Is that the way it's supposed to work? It seemed like the RPMs really jumped up higher than I expected.
Jack & Kay
2007 Tiffin Allegro 28DA
Ford Chassis V-10
Blue Ox Tow Bar to a 94 Honda Accord
FMCA #F341229
kyhawk
Villa Hills Ky
Our tranny does that too. I think it just helps the brakes slow the rig by using the engine. Nothing like a tranny that thinks for itself.
Janet & Ralph
2008 Winnebago Aspect 26A
2008 Ford Escape Hybrid
