RV.Net Open Roads Forum: Class A Motorhomes: Travel advice needed...Update.
 > Travel advice needed...Update.
Jim@HiTek
Gresham, OR, USA
Posted: 05/27/12 01:48pm Link  |  Quote  |  Print  |  Notify Moderator
What is US93 like between Las Vegas & Ely, Nevada? And switching to the SR-318, or should I stay on US93? Diesel, 37', no toad.
Any big hills, or is it mostly flat?
Thanks!
* This post was edited 06/01/12 05:44pm by Jim@HiTek *
Jim@HiTek
Have shop, will travel!
Visit my travel & RV repair blog site. Subscribe for emailed updates.
Fleetwood Bounder, '94
Cummins Diesel, 190HP, 36.5' with 50HP LP boost.
Black Rock Lava Park, Nevada
msmith1199
Central, CA
Posted: 05/27/12 01:58pm Link  |  Quote  |  Print  |  Notify Moderator
I have not been on that particular road, but I have been on others through Nevada so I can comment on those. The roads were all good and yes there are grades and high elevations. I came across 50 from Ely to Carson City a few weeks ag and I think the road probably averages about 6000 feet and goes up over 8000 on a couple of passes. Even though I've never done 93, I wouldn't hesitate to do it in my motorhome. Hopefully somebody who has been on it can give you more specific advice. I'm going to do it someday because I just love driving through those Nevada back roads. That is some of the most remote country in the lower 48. Not much out there but high desert and some great scenery.
2004 National Tropi-Cal T-350, Class A, Triple slide, 330 HP Cat DP.
2006 Dodge Dakota 4x4 or
2002 Harley FLSTF Fat Boy on a Trailer or
2004 Polaris Quad on the Trailer
msmith1199
Central, CA
Posted: 05/27/12 02:03pm Link  |  Quote  |  Print  |  Notify Moderator
Go to Google maps and look at the Satelite view. Nevada is a series of mountain ranges that run north-south. So when you go across 50 you go up one range and then down into a valley and up another. You do this a few dozen times. From looking at 93 on the satelite view it looks like it does cross a couple of passes, but for the most part it looks like it travels in north-south valleys all the way up the state.
Jim@HiTek
Gresham, OR, USA
Posted: 05/27/12 03:34pm Link  |  Quote  |  Print  |  Notify Moderator
Took your advice, msmith1199, downloaded google earth and flew the route. Looks pretty flat most of the way. Also looks remote and deserted most of the way. Thanks.
BigSkyBob
Helena, Montana
Posted: 05/27/12 03:52pm Link  |  Quote  |  Print  |  Notify Moderator
Been on 93 several times between vegas and Ely. All good road but as mentioned it has some grades and is a higher elevation. I came back from vegas the 1st of May and there was snow in the lower elevations then and cold in the KOA on 93 just outside of Ely. But I think Ely is over 6000 feet so no surprise.
2008 Monaco Camelot 40PDQ, 4 slides, 2012 Dodge Ram 1500 Hemi Quadcab 4x4. Blue Ox, Garmin 7200 GPS, Doran Pressure pro on all 10, M&G Brake, 50 amp SurgeGuard, FMCA, Coachnet.
Jim@HiTek
Gresham, OR, USA
Posted: 05/27/12 03:55pm Link  |  Quote  |  Print  |  Notify Moderator
So I'll be climbing 4,400 feet from LV to Ely. Hope that's over several hundred miles and not just a few.
nevadanick
Elko, Nevada
Posted: 05/27/12 05:35pm Link  |  Quote  |  Print  |  Notify Moderator
Take 318 but make sure you fill up in Alamo or Ash Springs. Only passes on the way to Ely will be near Ely.
obgraham
Eastern WA
Posted: 05/27/12 06:18pm Link  |  Quote  |  Print  |  Notify Moderator
Agree with Nevadanick. We run that road every year, both routes. 318 has been recently resurfaced, has fewer ups and downs, and is 40 miles shorter than 93. One climb into Ely on US6, but not bad. No fuel stops, though.
Jim@HiTek
Gresham, OR, USA
Posted: 05/27/12 06:37pm Link  |  Quote  |  Print  |  Notify Moderator
Fuel isn't much of a worry, I have a 95 gallon tank and get 10MPG. Ely is only 512 miles from where I am now in Flagstaff, and I'll probably refuel in LV.
msmith1199
Central, CA
Posted: 05/27/12 07:56pm Link  |  Quote  |  Print  |  Notify Moderator
I've come across 50 a few times and found there are many turnouts and it's almost all public lands out there so I pull off the side of the road and boondock. So no worry about finding RV parks unless you want hookups. One of these days I'm going to plan a week trip just to go out there and drive around on some of those north-south roads. I want to drive the ET Highway and get as close to Area 51 as I can. Not to mention the nuclear test site.
