bpounds
Whittier CA
83trekker wrote: bpounds wrote:
The water pump issue is obviously a leak. But it may be a leak inside the pump. The check valve may be bleeding your pressure backward.
How does one fix that? do they sell a rebuild kit? or is it just a matter of replaceing seals?
They sell kits. But often it is just in need of cleaning.
2006 F250 Diesel
2011 Keystone Cougar 278RKSWE Fiver
laknox
Arizona
Can't help with the water heater, but most water pumps have an internal check valve can can go bad or get******lodged in them which will allow the pressure to drop enough to trip the pump on. From my reading here, it looks like some are fairly easy to fix while others require a pump rebuild. You'll just have to figure out what pump you have and which category it falls into.
Lyle
1936 John Deere Model A
83trekker
calgary,ab,canada
I guess ill will have to pop it out and take a look, mine also has this big clear see through plastic piece comming off the one end of it. But what i am reading here i will have to take the main pump apart to see?
rattleNsmoke
Western Conn.
Here's something you can check. Take a look at our water tank bypass valve and make sure it is not in the bypass position. You could have a tank full of hot water and that's the reason the red light is not on and it won't fire, just no way to reach your faucets if still in bypass position.
Mike
2010 Cedar Creek 34SATS (The Beast) & 20k Curt Q20 roller slider hitch
2006 Ford F350 SRW,SC Powerstroke diesel Lariat
2003 Harley Heritage Softail (Hogzilla)
and a wifey with tons of patience....
83trekker
calgary,ab,canada
rattleNsmoke wrote: Here's something you can check. Take a look at our water tank bypass valve and make sure it is not in the bypass position. You could have a tank full of hot water and that's the reason the red light is not on and it won't fire, just no way to reach your faucets if still in bypass position.
Mike
No mine valves were open i made sure of it when i filled the tanks up.
83trekker
calgary,ab,canada
ok so i blow out the water heater with air, ton of******comes out including a moth. It lights and stays lit for an hour or hour and half, then goes out again, What do i look at, what would make it go out?Then light super easy again??
83trekker
calgary,ab,canada
When its lit up the fire is really blue and at the tip is orange if that makes any difference.
83trekker
calgary,ab,canada
Just watching and water leaking out very slowly through the pressure release valve on the top, ran some water in the rv and it stopped, again normal?
Mile High
Denver, CO
Are you at a campsite with hookups? If so it looks like your hot water tank is electric too.
Mine quit this spring - I got the tic-tic-tic everytime I reset the switch, but no gas. Did the same - blew it all out, nothing. I'll be installing a gas valve next week ($85). Hope that fixes it.
2006 Ford F350 4X4 SB CC SRW Powerstroke 6.0
2013 Redwood 36RL - full paint - disk brakes
"Comparison is the thief of joy! - Theodore Roosevelt"
83trekker
calgary,ab,canada
Nope at home, seems to be working now, but hot water runs out fast.
