RV.Net Open Roads Forum: Tow Vehicles: Compact Trucks?
Search only in Tow Vehicles
 > Compact Trucks?
Elidh
Loudonville, Ohio
Posted: 05/28/12 10:45am Link  |  Quote  |  Print  |  Notify Moderator
What are some decent (and affordable, of course) compact trucks with towing capacity of, say, 6000-7000#? We have a small garage, so don't want a monster truck. There are just 2 of us so we don't need a full back seat, probably just an access cab. Online, I see the Toyota Tacoma and Nissan Frontier. Any opinions on these or others? I should add we want to purchase a new truck.
* This post was edited 05/28/12 10:54am by Elidh *
fordsooperdooty
Posted: 05/28/12 11:03am Link  |  Quote  |  Print  |  Notify Moderator
The Nissan Frontier is built on the same chassis as the Nissan TITAN (Typo!)...which makes it a substantial smaller pickup truck. Combine that with a powerful engine...a 4.0-liter V6 that produces 261 hp and 281 lb-ft of torque, comfortable cab, nice ride and a 6500 lb tow rating and you have a truck that is often overlooked but a truly superb vehicle. Best of all the Nissan dealers tend to discount them quite a bit.
* This post was edited 05/28/12 06:37pm by fordsooperdooty *
Elidh
Loudonville, Ohio
Posted: 05/28/12 12:12pm Link  |  Quote  |  Print  |  Notify Moderator
Wow, fordsooperdooty - that's just the kind of info we need. Would the Frontier be a good match, then, for an ultralite TT with these specs: 20' long, dry weight 3344#, hitch wt 236#, GVWR 4636#
ifd22
Northern Kentucky
Posted: 05/28/12 01:39pm Link  |  Quote  |  Print  |  Notify Moderator
fordsooperdooty wrote:
The Nissan Frontier is built on the same chassis as the Nissan Tundra...which makes it a substantial smaller pickup truck. Combine that with a powerful engine...a 4.0-liter V6 that produces 261 hp and 281 lb-ft of torque, comfortable cab, nice ride and a 6500 lb tow rating and you have a truck that is often overlooked but a truly superb vehicle. Best of all the Nissan dealers tend to discount them quite a bit.
When did Nissan start building the Tundra, I'm guessing you meant the Titan?
2002 Outback 28BHS
2009 Tundra
Equilizer WDH
Prodigy BC
SoCalDesertRider
SanDiego, CA, USA
Posted: 05/28/12 01:42pm Link  |  Quote  |  Print  |  Notify Moderator
ROFL!!
05E350 6.0PSD
98Ranger
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
Callen Camper
92F350 CrewCab 4x4 351/C6
HD Springs Bilsteins,
4.56's & LockRite rear
SoCalDesertRider
SanDiego, CA, USA
Posted: 05/28/12 01:43pm Link  |  Quote  |  Print  |  Notify Moderator
I would look for a used Dodge Dakota with the 318 (5.2) V8....
SoCalDesertRider
SanDiego, CA, USA
Posted: 05/28/12 01:49pm Link  |  Quote  |  Print  |  Notify Moderator
I find it hard to believe that the Frontier and Titan are built on the same chassis. So far as I have seen, the Frontier is quite a bit smaller overall and about a foot narrower than the Titan. It's really not possible to use the same chassis to produce 2 vehicles that are as much as a foot difference in width. The entire axles and suspensions have to be different, and likely the frame width too. Possibly the 2 different chassis have some similar overall design ideas, but I doubt they are the 'the same'.
Elidh
Loudonville, Ohio
Posted: 05/28/12 04:52pm Link  |  Quote  |  Print  |  Notify Moderator
SoCalDesertRider, DH doesn't want a used truck.
GWolfe
Kansas
Posted: 05/28/12 04:58pm Link  |  Quote  |  Print  |  Notify Moderator
The Suzuki Equator is pretty much a re badged Frontier so you might want to check them out also.
Flagstaff 617SD 1991
Comet Camper 1963
coolbreeze01
Redding, Ca
Posted: 05/28/12 05:02pm Link  |  Quote  |  Print  |  Notify Moderator
I once had a Chevrolet Light Utility Vehicle. It could tow anything I hooked to it
2008 Dodge 3500 With a Really Strong Tractor Motor...........
LB, SRW, 4X4, 6-Speed Auto, 3.73, Prodigy P3, Blue Ox Sway Pro........
2007 Komfort 212 on 225 75R 15E Maxxis ST Tires.........
 > Compact Trucks?
