RV.Net Open Roads Forum: Tech Issues: Air Conditioner
 > Air Conditioner
Louie & Eva
New Haven Ct
Posted: 05/28/12 02:04pm Link  |  Quote  |  Print  |  Notify Moderator
We purchased this 5th wheel and it seems like when we fix one thing 2 more break.
We just brought it home from repairs, when I noticed that the plug over my sink in the bathroom was not working, the same with the plug over the kitchen sink and the plug on the outside of the camper, by the bottom of the awning. Now the air conditioner and the heater will not go on. The green light comes on but it will not go on. Can these all be conected some how. We have checked all the fuses and they are ok.
Montana 2008 Mountaineer travel trailer 32FLD
2006 Ford F350 PSD, Lariat, CC, LB, SRW and Blue ox sway control
rk911
Wheaton IL
Posted: 05/28/12 02:10pm Link  |  Quote  |  Print  |  Notify Moderator
are the plugs GFI outlets? if so they may have tripped off. there should be a button on one or more in the center of the plate. press it to reset. if you have any other GFI outlets in the 5er resrt them as well.
73,
rich, n9dko
www.bananaboatbytes.com
I know a guy who's addicted to brake fulid. He says he can stop anytime.
2000 Itasca Suncruiser 35U
'46 Willys CJ2A
'03 Jeep Wrangler TJ
'10 Jeep Liberty KK
Louie & Eva
New Haven Ct
Posted: 05/28/12 02:41pm Link  |  Quote  |  Print  |  Notify Moderator
We already reset them, it was not it.
Chris Bryant
DeLand, Florida, USA
Posted: 05/28/12 02:47pm Link  |  Quote  |  Print  |  Notify Moderator
50 or 30 amp service? Running through any adapters? Does it have a transfer switch?
-- Chris Bryant
My RV Service Blog
The RV.net Blog
rk911
Wheaton IL
Posted: 05/28/12 02:49pm Link  |  Quote  |  Print  |  Notify Moderator
is your 5er equipped with a generator? if so will the outlets and AC work on the genny?
are the other 120-vac appliances and outlets working? if you have 50-amp service you may have lost one leg.
hershey
Albuquerque,(fulltime) NM, USA
Posted: 05/28/12 04:30pm Link  |  Quote  |  Print  |  Notify Moderator
I also think that its the GFI thats at fault for wet/outside areas but not the AC. Make sure that your connected to power when your resetting the GFI, some will not reset without power connected.
The AC? The obvious place is the breaker inside your RV which I'm sure you've already checked.
hershey - albuquerque, nm
Someday Finally Got Here
Superman was an illegal alien.
NASCAR 14 - 99
 > Air Conditioner
