eomrat
West Exas
I am being told that my Sunchaser 5th does not recharge its batteries while being pulled down the road and that the only way to recharge them is by plugging in. This, of course, necessitates purchasing a generator.
This cannot be true.
chuggs
One way to tell...take a voltage measurrment of the TT battery withou the TV attached...and again with the TV attached/ engine running. If the voltage goes up...it is getting something from the TV alternator.
Hamops
Oshawa, ON, CA
I find that highly unlikely. Another way to ensure that your TV is connected to your 5vr battery is to disconnect the positive of your 5vr battery. Connect the trailer umbilical to the TV. Measure for nominal 12 volts from the battery cable that you disconnected to ground. If 12 Volts appears on the meter then you're connected to the charging circuit on your TV. If not, then you may have to install the charging circuit. Reconnect the positive cable to your battery.
It's important that you have 12 Volts at all times while you are towing to keep some of your services operating, like your fridge. You may not get much charge to your battery if you are connected to the TV charging circuit, but then you won't drain your battery either, because you are getting 12 V power from your TV.
Cheers
Helen & George VE3INB and Max (Bichon Frise)
2006 Silverado 2500HD D/A, Isspro Gauges, Linex, Westin Nerf Bars, Fold-A-Cover
2006 Cruiser CF30SK.
Reese 16K Slider, Bedsaver, Prodigy Controller, Rearview Camera, JT StrongArms
smkettner
Says who?
675 watts solar
Francesca Knowles
Port Hadlock, Washington
eomrat wrote: I am being told that my Sunchaser 5th does not recharge its batteries while being pulled down the road and that the only way to recharge them is by plugging in. This, of course, necessitates purchasing a generator.
Perhaps you misunderstood the meaning of the words "plugged in". On its OWN, the rig can't recharge its own batteries- but any 12v battery-equipped trailer can be recharged during travel by way of being plugged in to the tow vehicle.
It sounds to me like the fault may lie with the hookup to the tow vehicle.
It's a simple matter for your vehicle to charge the trailer battery, but it does require an active connection to the vehicle's charging system.
" Not every mind that wanders is lost. " With apologies to J.R.R. Tolkien
enblethen
Moses Lake, WA
Welcome!
Normally the 5er or TT is charged going dowen the road through the trailer connector.
Your TV should have a fuse connected through a relay or a fuse with no relay. It depends on what your TV is and whether it was wired up properly.
What is make and model of TV? GM requires the installation of a 30 amp fuse in fuse block under the hood. Some Fords do not have the control fuse installed that operates the relay. Normally under the hood.
How are you connecting to the 5er? Factory receptacle has all wires connected. Custom installs may not have included charge wire.
Yes, it should charge is fully wired correctly.
Bud
USAF Retired
Suzuki XL7 pushing Pace Arrow
Camp I am
Wisconsin
Your truck may not be providing 12v power also. Check to make sure that the fuse is not blown and in place in the truck for providing charge power to the trailer. I've had one truck so far that could provide power but from the factory the fuse was not installed.
Sahm I am's Husband
2006 Chevy Silverado 3500, LT3 CC/LB 4WD SRW LBZ Duramax/Allison
Keystone Cougar 327RES
Curt Q5 20K / Prodigy Brake Control / Rotochocks / Trail Air
Rallies attended: "               "
Sleepovers 3
eomrat
West Exas
chuggs wrote: One way to tell...take a voltage measurrment of the TT battery withou the TV attached...and again with the TV attached/ engine running. If the voltage goes up...it is getting something from the TV alternator.
TT means "Travel Trailer" and TV means "Travel Vehicle". I am really knew to all this.
eomrat
West Exas
smkettner wrote: Says who?
There is a big shop here in El Paso, I don't remember the name but they appear to be the "go to" guys around here.
2oldman
Winchester WA
eomrat wrote: This, of course, necessitates purchasing a generator.. or a solar panel.
