RV.Net Open Roads Forum: General RVing Issues: Sleeping while generator is running?
 > Sleeping while generator is running?
GizmosMom
Central Texas
Posted: 05/29/12 03:21pm Link  |  Print  |  Notify Moderator
Thanks, again. I phoned the county offices today and they initially were not clear if camping was allowed. But I told them there was a sign that said that one could camp for no longer than five days in a row. So the man said that if the sign was there we could go ahead.
The park has two areas so if anyone else is there in a tent (which I doubt) then we could move to the other area.
My main concern was running the gen while we sleep as we have done it before and the gen exhaust points away from our van. The gen is built in.
Marilyn w/ Joe, 2000 Xplorer Class B van, usually pulling a Ranger bass boat.
Smudge, (in photo) a Shih Tzu/Yorkie Mix and Gizmo is waiting at the Rainbow Bridge
jspringator
Versailles, KY 40383
Posted: 05/29/12 03:25pm Link  |  Print  |  Notify Moderator
Make sure you have 1 or 2 Carbon monoxide detectors. I prefer 2. We used our eu2000 this weekend at a boat ramp parking lot while we slept in the boat. The genset was locked to the rear bumper of the truck and pointed in the opposite direction. You can't be too careful with CO.
Jim & Sherri
05 Jayco Eagle 308 FBS, Dual Cam
2001 Ford Excursion 4.30 LSD,V-10,2WD,RAS,5-Star tuner
Honda EU2000 & EU1000 gensets;
2000 watt Tripp-Lite inverter/charger APS 2012
Saturn SD365 inflatable, 15 hp 2 stroke Yamaha
"Scout" Springer Spaniel
MPI_Mallard
McGregor Ontario,St. Cloud Florida
Posted: 05/29/12 03:49pm Link  |  Print  |  Notify Moderator
Regarding running a genny at night we had a terrable incident on the way home from Florida this spring,while over-nighting at a Fling J south of Cinncinatti at about 2:30 AM our carbon monoxide alarm went off and woke us from a sound sleep,what had happened was that some very ignorrant self obsorbed person with a toy hauler pulled up right next to us and was running his genny with the exhaust pointing right at my side door and of course the fumes were coming in through the storage bay door just in front. I got up and went outside and thought how it was impossable for this goof NOT to know this was wrong to do! as a result i said to hell with it and continued back to Canada with five hours of sleep. This is the first time i have ever experienced a negative thing on the road by another RV'er in the fifteen years i've been RV'ing so i guess the odds had to catch up with me.
07' Dodge 3500 6 speed Cummins Diesel Dually/6.7L Bully-Chipped /
Exhst Brake/07' Cedar Creek 37CDTSD Daydreamer fiver
Mallard @ Frau Blücher
Red Green:
Now lets Bow your heads for the men's prayer.
I am a man, but I can change.
If I have to, I guess...
ng2951
Louisiana, USA
Posted: 05/29/12 04:01pm Link  |  Print  |  Notify Moderator
We do it all the time, and yes the CO detector will wake you up.
I will suggest that you build a generator alarm. I am adapting one of those automatic flashlights with a piezo horn so that if the power quits the piezo horn switches on with the light. I am more worried about theft (though with the cable, I don't think they will get away to beat my 12G).
It is smart to know which way the wind is blowing and make sure your exhaust moves away from the RV. Most of the tragic stories of CO poisoning have to do with pointing the exhaust in the wrong direction. One I saw had the exhaust all but blowing into the TH.
If you can locate away from your trailer all the better.
Foard County News & Sassy Schoolmarm
with Lady & Chloe
2012 Unleashed 27SBU
2013 14 days camping
2012 50 days camping
'07 GMC Sierra 2500HD Classic 4x4 LBZ Duramax Diesel
Honda 2000sThe Bayou Bounty Hunters Cowboy Club
The Single Action Shooting Society
Handbasket
Asheville, NC
Posted: 05/29/12 04:08pm Link  |  Print  |  Notify Moderator
Giz'mom, I'd strongly advise you to inspect the Onan's exhaust as much as possible. I think your Xplorer has a 4.0? Dunno how much of the internal muffler inside the green box is visible thru the access door, but I'd consider getting a mechanic's inspection mirror and using that and a flashlight to do a lookee-lookee for split seams, etc as much as you can. Check the tailpipe underneath for pinholes and loose clamps. Shine a light up into the compartment to look at the seams and corners.
Yes, I've done it quite a few nights with my 2.8. I check the CO detector each time, and plan to replace it this year.
Jim, "The easiest way to find something lost around the house is to buy a replacement."
'06 Tiger CX 'C Minus' on a Silverado 2500HD 4x4, 8.1 & Allison (aka 'Loafer's Glory') www.tigervehicles.com
Francesca Knowles
Port Hadlock, Washington
Posted: 05/29/12 04:10pm Link  |  Print  |  Notify Moderator
Only last Fall:
Generator fumes Kill 5 Sleeping in Rv
Here's the generator- right next to the RV
Portables are definitely more dangerous to the owners, if put too close to the rig. As noted, though- many folks are pretty careless about how close they get to other folks with the fumes...
" Not every mind that wanders is lost. " With apologies to J.R.R. Tolkien
Desert Captain
Tucson
Posted: 05/29/12 04:13pm Link  |  Print  |  Notify Moderator
These are some of the many reasons why we avoid the need for AC unless there are electrical hookups available. Happily here in Arizona it is a simple matter to camp at higher, thus cooler, elevations. I won't run my Honda's all night to provide AC, too easy to avoid the need in the first place. If I'm not awake they, and usually just one, are not running. No possibility of theft or danger of carbon monoxide.
I know that much of the rest of the country doesn't have our altitude and weather options but if carbon monoxide doesn't seriously scare you.... it should! Even if you are doing everything right it only takes one moronic bozo (as noted above), to pull in, fire up and kill you and yours. Be safe out there.
zigzagrv
Nazareth, PA
Posted: 05/29/12 04:47pm Link  |  Print  |  Notify Moderator
We usually travel in the Spring or Fall, so no need for A/C during the night. In the Summer, we go camping with the GKs, so we are plugged in at the cg. However, this summer we will be traveling and occasionally boondock overnight, so we will be running the gen for the A/C at night. I don't feel comfortable running the gen while sleeping, so I got a GENTURI, which puts the exhaust above the roof. Peace of mind.
Ron
2003 Gulf Stream Ultra Supreme 33'
F53 Class A
'95 Tracker toad
coolbreeze01
Redding, Ca
Posted: 05/29/12 05:07pm Link  |  Print  |  Notify Moderator
bikendan wrote:
nearly all the campgrounds i know of, don't allow generators running during sleeping hours, no matter how quiet they are.
nearly all that allow generators, have strict hours of operation.
most are 8am-8pm.
+1
2008 Dodge 3500 With a Really Strong Tractor Motor...........
LB, SRW, 4X4, 6-Speed Auto, 3.73, Prodigy P3, Blue Ox Sway Pro........
2007 Komfort 212 on 225 75R 15E Maxxis 8008 Tires.........
W4MBG
Williamsburg, VA
Posted: 05/29/12 06:46pm Link  |  Print  |  Notify Moderator
dont forget to replace the CO detector every 5 years, or go by what it says on the back. we just replaced ours. it was dated 1998! put a sticker on the front of the unit to remind you. i had to remove mine to find out that it was original to the rv.
also, as said above, a gen-turi is great. either purchased or home-made.
1999 Winnebago Minnie, 29', Triton V10, mostly stock. So far...
