RV.Net Open Roads Forum: Class A Motorhomes: Onan 5500 won't stay running
 > Onan 5500 won't stay running
Marcusp
Sevierville TN
Posted: 05/30/12 10:57am Link  |  Quote  |  Print  |  Notify Moderator
I was camping at Charlotte Motor Speedway this past weekend and had problems with generator running. The generator would run for approx. 1hr then just die. The tank was full of fuel and I have a fault code of 41. The generator is an Onan 5500 HGJAB. Has anyone one else expirenced this problem if so what did you have to do to correct ? Generator has less than 200 hours. Also I changed fuel filter before I found fault code and purchased fuel pump but have not installed.
MountainAir05
New Mexico
Posted: 05/30/12 11:32am Link  |  Quote  |  Print  |  Notify Moderator
could be the Brushes or winding. Some models are different. You will have to check out he board.
Marcusp
Sevierville TN
Posted: 05/30/12 01:51pm Link  |  Quote  |  Print  |  Notify Moderator
Now I noticed the fault code is now 36 and no longer 41.
USARMYCW
TEXAS or somewhere in between
Posted: 05/30/12 03:24pm Link  |  Quote  |  Print  |  Notify Moderator
The first thing I would check is the fuel filter. I had the same problem and after $200 for diagnosing the problem and the cost of a fuel filter it ran good again.
koda55
Jacksonville
Posted: 05/30/12 06:26pm Link  |  Quote  |  Print  |  Notify Moderator
Code 41 is generator rotor fault. Corrective action is see an authorized Onan dealer.
Code 36 Engine stop contoller, Engine stopped without command by controller. Corrective action:
Gas model- check and fill the fuel tank. (I know you have a full tank.) Tube could be higher than engine tube.
Secure the spark plug leads to the spark plugs.
Replace the spark plugs.
Service the air cleaner.
Check for mechanical damage.
This right out of the book as problems and corrections.
